Guest chooch Posted April 25, 2012 Share Posted April 25, 2012 Hi What are peoples thoughts on external wastegates? I was thinking Tial or Turbosmart as there's not many really to consider... http://www.tialsport.com/prod_wg_38.htm or http://www.turbosmart.com.au/product/ultra-gate38 But my attention has been turned to the new watercooled version http://www.tialsport.com/prod_wg_mvs.htm Has anyone used these, how are they for reliability Is the plumbing a nightmare? Would you run a water feed to the actuator before or after the turbo or in parralel? It can also be ran without a waterfeed, how does this compare for reliability? Cheers, Ewan Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 25, 2012 Share Posted April 25, 2012 Do you have stock turbos? Quote Link to comment Share on other sites More sharing options...
Guest chooch Posted April 25, 2012 Share Posted April 25, 2012 no Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 25, 2012 Share Posted April 25, 2012 Then don't you already have an external wastegate? Quote Link to comment Share on other sites More sharing options...
heckler Posted April 25, 2012 Share Posted April 25, 2012 I had the water cooled Tial MVS on my TO4z single, except didnt have the water feed connected. its a wastegate, does exactly what is says on the box. Quote Link to comment Share on other sites More sharing options...
Guest chooch Posted April 25, 2012 Share Posted April 25, 2012 Thanks heckler Changing manifold from single 50mm wastegate to 2 x 38mm wastegates, just want to get an idea of the market pros / cons. If people report problems then I probably won't buy said product. Maybe there is another brand I have overlooked. Cheers, Ewan Quote Link to comment Share on other sites More sharing options...
