T2 MSW Posted April 24, 2012 Share Posted April 24, 2012 Does anyone know which pin on the connectors that goes into the back of the dash cluster is for the abs warning light?? I've looked at the wiring diagrams but I can't work it out. It's either blue or wht/blue according to the diagram but they don't exist on the connectors. Only thing I can think is the jspec is different!? Need it to get the car through an MOT. Link to comment Share on other sites More sharing options...
T2 MSW Posted April 28, 2012 Author Share Posted April 28, 2012 Anyone?? Link to comment Share on other sites More sharing options...
merckx Posted April 28, 2012 Share Posted April 28, 2012 What about trying to work backwards from the warning light. If you're trying to stop it illuminating it may not be such a good idea as warning lights like this are set up up to illuminate when you put the ignition on to show they're all functioning correctly, a mot tester may spot that it's not working like it should. Link to comment Share on other sites More sharing options...
T2 MSW Posted April 28, 2012 Author Share Posted April 28, 2012 The car has no dash in it, all I have is the dash connectors I'm not trying to stop it I need to put an led on it as its now an MOT failure not to have a warning light. Link to comment Share on other sites More sharing options...
