Guigsy Posted April 23, 2012 Share Posted April 23, 2012 Any clue what the deal with my aux belts? One was frayed I thaught from damage with a stray plug in the engine bay. The belt was replaced, and on Saturday. A week or so later I heard an odd flicking noise. It was while i was away from home and turned out was a bit of the belt flapping arround. Not a thick bit probably only 1-2mm thick so just trimmed it down to get me home. Now it's still fraying. And the fray is about 5cm long again already. Obviously I'll replace it. But is there anything I should be checking. I can't see anything rubbing :/ Quote Link to comment Share on other sites More sharing options...
keron Posted April 23, 2012 Share Posted April 23, 2012 i would take a closer look at the aux pulleys....especially if you have the plastic one on the tentioner. also check your crank pulley too as if it has separated, it can move fowards and backwards and can wear the belt... Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 23, 2012 Share Posted April 23, 2012 Another crank pulley bites the dust by the sounds of things Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 23, 2012 Author Share Posted April 23, 2012 It's got a Titan crank pulley on it I think. Aircon was re-fitted recently so was thinking that might be it :/ P.s keron - u got a rear passenger upper wishbone in good nick? Discovered one of mine is iffy. Quote Link to comment Share on other sites More sharing options...
keron Posted April 23, 2012 Share Posted April 23, 2012 i may have mate, i have a few new cars in for spares so should have one....im starting to strip one down tomorrow so can check for you... Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 23, 2012 Author Share Posted April 23, 2012 Would be great if you do. Need one before dragonball lol Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2012 Share Posted April 23, 2012 Have you put a straight edge across the pulleys to check alignment? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 23, 2012 Author Share Posted April 23, 2012 Nope. But I will do tonight. Quote Link to comment Share on other sites More sharing options...
