Turbo recommendation needed
V8KILR
I'm running a MasterPower T70 (69mm compressor) Q-trim with exhaust AR 1.00 and it is just way too slow to spool with the TH400 with 3500rpm stall that I have just installed in the car. It was making 450rwkw when manual and is probably around 410rwkw now. It is making around 6 psi boost at 4000rpm and full boost by 4800rpm.
I'm thinking about a MP T70 Q-trim with either a 0.81 AR or a 0.68 AR exhaust to suit the auto better. Any recommendations as to which would be best?
Edited by V8KILR (see edit history)
I've organized a 3800rpm stall converter that takes much less torque to flash the converter, as the one I had in their was designed for way more power/torque then my car is making at the moment. I will be putting this in the car in the next week or two and then I'll get it tuned with that converter, which should make a huge difference. :)
