na 94 exhaust and intake
NOODLE
whats the best induction and exhaust set up for the na, ive already looked at the mvp exhaust manifold and seen a thread on here saying it could foul on the steering rack, im looking at a japspeed cat back with a decat, i just wanna know what the best bore of exhaust is best for the na without losing to much back pressure and has anyone used the injen induction kit because as far as i can see it bolts straight on to a maf meter which mine doesnt seem to have in the same position as the one used in the advert for the kit. any help is apreciated :-)
You'll need to use a 2.5" bore for the exhaust. Buy a universal 45 degree bend and a 30cm straight pipe for your intake. Type Apiro pipe into ebay and a good few come up. you should be able to build a good intake system for about £60 including a filter. I'm taking my cone filter off though as I'm sure i'm suffering from too much warm air from the engine bay getting sucked in, so I'm going with the factory airbox with an aftermarket element and extra intake cut into the side and ducting extra cold air in from the inner wing blanking plate that the TT's use as an intercooler route along with my baffleless pipework and Crankcase breather venting to air via a small filter.
ok cheers for that i will look it up i have wondered about the heat from the manifold as well, i was gonna use a heat shield but that sounds like a great idea, i might look at that route myself :-) i will have a look in the morning and see what room i have to play with and i will let you know how i get on
do u know what the diameter was on the pipe u brought?
76mm I think....just measure the inner diameter of the big rubber connectoron the TB mate., you'll also need an intermediate connector to join the 2 bits of pipe. Get a bend that has a connector on it for your small breather tho.....it requires a 6mm silicone hose. I replaced all of my hardened vacuum pipes as well, seemed to make a difference to me but might be psychological/optomistic! haha
ok cheers for the help i will get that sorted and let you know how i get on :-) ive notice the rear breather pipes past it now so will get it changed
thanks again
Go to Whifbitzs and get a 2.5 exhaust from there. If you are going full decat like me I suggest the 2.5 twin box exhaust he has for sale as well.
how would the double decat work if i used the mvp manifold? will it effect alignment of the exhaust at all? i heard that the mvp manifold can scrub on the steering rack is that true?
The MVP website says it's the same as the XERD manifold, the XERD manifold definitely doesn't clear the steering column on a RHD Supra, it clashes on the outer edge where the 6 pipes go into 1, with some heat and a hammer the area can be flattened to give enough clearance.
The manifold replaces the stock cast manifolds AND the 1st cat, so it connects up to the 2nd cat/2nd decat pipe. The pic below shows the stock cast manifolds and 1st cat above and a tubular NA manifold below, not the MVP one but the fit is the same.
http://img291.imageshack.us/img291/2048/mani2jpgzp8.jpg
Pic below shows the exhaust manifold I use to produce which was designed to fit a RHD Supra, you can see on the pic where some manifolds will clash with the steering column.
Also check what O2 sensor bosses the MVP manifold uses, the old XERD manifolds used screw in bosses which weren't compatible with the standard 2 bolt O2 sensors.
As you can see mine uses screw in type sensors, just make sure they are the right type, single wire sensors, clip the wire from your old ones and use electrical connectors to plug them back in. 4 years on and my aem ugeo shows the car maitians perfect 14.7 at idle and light throttle dipping down to 12.1-13.5 on wot. regardless of which type of manifold you get, the 16year old + sensors might be ready to be replaced anyways
do u still do these manifolds or can u get ahold of one? kinda want a manifold which i dont have to modify it to fit, mainly because id probably bugger it up, ye i rekon i will change the sensors ther same time as i change the manifold to play it safe
Edited by NOODLE (see edit history)
