Josh42 Posted April 22, 2012 Share Posted April 22, 2012 Just a quick one, other than a w58/r154 box, clutch, diff, bell housing, ecu and gear selector is there anything else required to do a conversion? Would my a02b LSD work with the w58? And what would the approximate cost be? Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted April 22, 2012 Share Posted April 22, 2012 clutch pedal? lol Quote Link to comment Share on other sites More sharing options...
supra steveo Posted April 22, 2012 Share Posted April 22, 2012 master cylinder, slave cylinder, clutch line, manual sub panel Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 22, 2012 Author Share Posted April 22, 2012 I was including those parts within the term "clutch" however I suppose I should of said clutch and assembly:) lol Quote Link to comment Share on other sites More sharing options...
Guest JohnSupra1 Posted April 22, 2012 Share Posted April 22, 2012 Box, Diff, Prop, Drive shaf, Bellhousing, Master Cylinder, Slave Cylinder, Clutch, Flywheel, Tunnel, Rubber mount shifter, Manual gear surround, Cluthes padels, I think bit more that it. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 22, 2012 Author Share Posted April 22, 2012 I forgot about the tunnel actually... And the drive shafts.... But importantly, will my a02b work with the w58? Thanks chaps! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 22, 2012 Share Posted April 22, 2012 the gears willbe very long and if you are na this willmake the car feel very slow. not tomention your speedo being miles out. i ran an a02b with a 58 withapprox 380lbft and it was pewtty good. but im backpn a a01b now and its alot "quicker"accelarating Quote Link to comment Share on other sites More sharing options...
Jamesy Posted April 22, 2012 Share Posted April 22, 2012 I have the following for sale if needed: Manual brake pedal Manual dash gear surround panel Short shifter Quote Link to comment Share on other sites More sharing options...
