Advice: What would you do with these wheels?
SupraDan24
Well, to cut a long story short a few months ago i was pretty much ripped off on a set of wheels. They were too far away for me to go view so i trusted the guy was open and honest about them and turns out he wasnt...not even remotely. I have them now so thats all that matters. I have been trying, unsucessfully, to resell them on Driftworks but haven't been able to as of yet, probably because i was trueful about the condition. Yesterday i decided to bite the bullet and give it a go at refurbing them myself, herein lies the problem. The centres of the 2 rears are perfect, the front two, not so much. There is some chrome peel/lift around the centre near the bolt holes. Now from say 6-10ft away its hardly noticeably, but pretty obvious from any closer. Also, when i masked up the wheel to spray the inner lines black in an effort to make them blend in better with the wheel, piece of the chrome came off with the masking tape. I knew this was a risk before i did it but i didnt have any other choice. I've included a photo of the chrome lift.
It seems to me i have a couple of options, i'm just not sure which to go with so this is where i would like peoples opinions.
1.) Carry on refurbing them, and just put them on the car with the chrome peel present and ignore it.
2.) Take the plunge and totally remove the chrome (no going back once i start though) and hope i can polish up the metal underneath. Judging by the weight of the centre, i'd say it was Steel and not alloy as it's quite heavy. There's a chalky white residue under where the chrome was, it doesnt appear to be rust.
3.) Spray the centre in white with Plastidip and see how it comes out. I can always remove it if i dont like it.
4.) Any other suggestions??
  • Replies 50
Posted Images
Either carry on refurbing yourself, remove the chrome and see how it goes (you can always paint the lip if it goes wrong or send them to ibrar to sort out) or get them refurbished profesionally from the off
The actual refurbing isnt the problem, ive already removed the curbing and mirror polished the barrel, i'm just not sure what to do with the centre. I'm trying not to waste more money on them which is why i'm doing the work myself. I really like the chrome look on the centre's which is why i'm umming and arring about removing it. I'm thinking i may have too though, as i'll never be happy with the finish if i dont, it just seems like a massive waste to remove the chrome off the two wheels that are perfect :(
Depends what colour you want the wheels to be in the end.
You could just do away with the chrome all together and spray the outers silver. Halfords do a Chrome spray paint too which is pretty decent for what it is. Obviously it's nothing like real chrome but it is pretty shiney. I painted the hexagon in the middle of my centrecap with the chrome paint.
Peter
It's just the centre piece i need re-chromed Dunk, i'll go take a photo now. Tbh though, i imagine it will be more money than i am willing to pay so i may just go all out and strip the chrome and see if i can polish up the metal underneath using one of the methods i found on the internet. If i can't then i have the option of painting them.
A lot depends on what you find after you've got the chrome off, there will be nickel under the chrome and
possibly copper under the nickel.
I will make a copy of the pic you posted above and show the chromer i use, he has done some top quality
work for me and wasn't crazy expensive but it depends what you call expensive i guess :)
Did you get a quote off Ibrar? Reason I say, by the time you buy the stripper & paint etc then the effort in getting it right (which is going to be quite difficult by the looks of it). The last thing you want to do is spend a load of time, money & effort then for it not to be 100%. That would be enough for me to drop them in the bin (then again my patience is very thin).
To send the wheels off to ibhar and then to pay for them to be done......and then spend the money on to deliver them back to dan would be a lot more expensive then buying some stripper and putting some effort into it.
If you have the time dan before you go offshore again just strip them right down and respray the lot in that chrome look paint
I doubt you'll be able to by the stripper and will need to go to a specialist that has some
fairly serious chemicals, you also need to be very carefull as the chemicals req are strong enough
to attack the aluminium.
Speak to Ibrar is a very good idea and i'll also chat to the chap i use and see what he says.
Stripping chrome and nickel isn't a diy job you do at home
What he said, the guy I used made the recepticle/tank for the chemicals out of stainless steel....after 4 months it ate a hole in it! They had to make a new tank from a different grade and 3 times the thickness. If you were to dip a finger into this stuff, even for a split second, it would remove the skin...no questions asked!
Yes indeed.
I helped Ibrar when he first set up his business and i got a tank made for him and used to help out
stripping the wheels and then media blasting them etc.
We only used Phosphoric acid for stripping powder coat and thats bad enough and it wont
touch nickel or chrome.
Im reading up on this and you can use a Muriatic acid to remove the chrome but apparently
this is Hydrochloric acid so not nice stuff.
Apparently, the gasses given off by that stuff cause serious brain damage, as we can see....... :p haha
Now if i was a tad over sensitive that comment could be very hurtfull
and unkool :D only kidding :)
Yes it stinks and breathing it in for any length of time isn't a good idea, we had the tank outside
so it wasn't too bad and i didn't spend too long putting the wheels in it or removing them.
The plus with phosphoric acid is tap water neutralises it.
Ibrar is very good at what he does, but he also isn't very cheap so he's a last resort at the moment. The whole point of me refurbing the wheels is so that i can either get them to a point where their useable, or sell them back on and not be out of pocket. So far all i have used is electricity, some wet and dry and some cutting pad, all of which i had in my garage. There's a place down the road from me called Aerocoat that strip and refurb wheels, i'm going to take the centre down there and see what they can do for me. They're also pretty cheap :) I'm also looking round my house for a magnet so i can see if whats underneath the chrome is stainless or not. If it is then i can just polish it to a mirror shine and be done with it.
Here's a couple of before and after pictures of the first barrel i've started. It's not finished yet as i'm waiting for some higher grade flapper wheels to arrive so i can go over it again, then hand sand it up to around 800grit, then try again with the compounds and finishing wheels. The after pictures are the finished i got with an 80grit flapper wheel, ive ordered up to 320grit.
Before
After
