skyludeboy Posted April 22, 2012 Share Posted April 22, 2012 Any one know the part number for the reverse gear selector shaft on a v160 gearbox, I rang toyota they go they cant help me as their system dont tell them which selector shaft is which lol and theres 4 to pick from. Link to comment Share on other sites More sharing options...
straightsix Posted April 22, 2012 Share Posted April 22, 2012 Is it UK or jdm? If you pm me your chassis number I might be able to find it on the epc. Link to comment Share on other sites More sharing options...
merckx Posted April 22, 2012 Share Posted April 22, 2012 Are you after the "Reverse idler gear shaft" ? 33451-0W010 I got this from my own epc, if you want to look for yourself you can use the following website (register to see the diagrams) . http://www.toyodiy.com/parts/ Link to comment Share on other sites More sharing options...
skyludeboy Posted April 22, 2012 Author Share Posted April 22, 2012 the only problem is I do not have a chassis number for a supra, the engine and gearbox have been fitted to a toyota chaser jzx100, what I do know is the gear box is a v160 of a jdm spec supra twin turbo if that helps? Link to comment Share on other sites More sharing options...
straightsix Posted April 23, 2012 Share Posted April 23, 2012 I'll take a look when I'm back home Link to comment Share on other sites More sharing options...
merckx Posted April 23, 2012 Share Posted April 23, 2012 (edited) [ATTACH=CONFIG]150406[/ATTACH]the only problem is I do not have a chassis number for a supra, the engine and gearbox have been fitted to a toyota chaser jzx100, what I do know is the gear box is a v160 of a jdm spec supra twin turbo if that helps? You don't necessarily need to know the chassis number. The "Reverse idler gear shaft" ? 33451-0W010 is the same on all of the Supra 6 speed gearboxes (V160 and V161). Or ,are you after the "Shaft, Reverse Shift Fork" ? You've got a choice of 2, see the diagrams below. Edited April 23, 2012 by merckx (see edit history) Link to comment Share on other sites More sharing options...
skyludeboy Posted April 23, 2012 Author Share Posted April 23, 2012 (edited) i am after the reverse shift fork ^^ thank you for that diagram, I cant believe my local toyota dont know which one is which. Edited April 23, 2012 by skyludeboy (see edit history) Link to comment Share on other sites More sharing options...
