Chris Wilson Posted April 21, 2012 Share Posted April 21, 2012 My high tension oil pump seals, special seal with added lip tension, a good bet for fixing the dreaded front seal leak where the crank has a wear groove worn by the old seal. £28 plus VAT each Stock oil pump seals due in this week. Price to follow. Rear main bearing seals, nearly a 1/3 rd of Toyota price, a small job lot, will soon go. My price £18.98 plus VAT. Gear shaft selector seals for six speed manuals, a special seal that doesn't entail you performing the almost impossible task of getting the old seal out without scoring or scratching the selector shaft itself and making things 100 times worse. Just thoroughly clean with brake cleaner, tap the old seal in further, and put the new on in in front of it. A trick used on old BL cars with similar selector shaft issues. These special seals are £4.80 plus VAT each, I have but 6 of them. Cam shaft seals, 1/2 list price. My price £4.80 each. Now a few back in stock!!! Gearbox rear seals, manual 6 speed only, nearly 1/2 Toyota price, very few left. My price £19.82 plus VAT. Postage can be by insured next day courier at £5.80 plus VAT, or a your risk £2.50 plus VAT by normal mail. I pair N/A genuine Toyota multi shim exhaust manifold gaskets, been on an engine that someone brought to me to fit, started it, ran it for 10 minutes, found it a scrapper and he bought a TT conversion. £14 pair. Mint, still retaining embossing, so will definitely seal as new. These are DEAR from Mr T. I set valve stem seals, inlet and exhaust, offers. New of course. One only TT standard head gasket. E-MAIL responses please, or ring me, no PM's, see sig. Thanks. Link to comment Share on other sites More sharing options...
Marco79 Posted April 21, 2012 Share Posted April 21, 2012 Email sent about na shim gaskets Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 22, 2012 Share Posted April 22, 2012 I'll have a rear main bearing seal please, I'll take it off you when i visit you next weekend. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2012 Author Share Posted April 22, 2012 I need to speak to you re next weekend, it would have to be SUNDAY AM if you want to come over, tied up on Saturday, sorry. Will reserve you a rear main seal. Cheers. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 22, 2012 Share Posted April 22, 2012 I need to speak to you re next weekend, it would have to be SUNDAY AM if you want to come over, tied up on Saturday, sorry. Will reserve you a rear main seal. Cheers. Ok thanks Chris, I'll let you know via email if Sunday is ok for me to come up Link to comment Share on other sites More sharing options...
