teddan goes for 1000hp
teddan
I am going to built a 1000hp single turbo. So this will be my building thread.
I bought the car last summer. Last owner was a truckmehnical guy but nothing was done properly and it was not finlized.
The cables for the fuelpump was just scaled and wiring togheter so the fuelpump was running randomly it was also running on the first ignitionstage...not good.
The car is a 6speed with a greddy trust kit but some parts will be remomved because we are going for 1000hp:p
NEW SETUP 2015
Engine
Cp pistons (20 over)
Upgraded wristpins (0.250 wall thickness)
BC sportman rods with ARP625+ (Should be same as Brian Crower Pro Series Rods)
Titan billet main caps with ARP bolts
ACL Race bearings
Main L19 bolts
Brian Crowe 280 Race Cams
Brian Crowe Springs and Retainers kit
Titan Cam Gears
Welded timing gear
Billet Tensioner
Greddy Timing belt
VAG ignition coils
1.5mmm cometic headgasket
Fuel Setup
Bosch 2200cc
Dual 6AN PTFE Feeding lines
6AN Retur line
2xWalbro 450 LPH
Aeromotive fuelpressure regulator
Flexi fluel sensor
Engine mangement
MaxxEcu Plug In
Google Nexus7 GEN2 tablet to MaxxECU
MaxxECU PWM module
Ethanol sensor for fuel temperature and ethanol content
Exhuast and Turbo
Precision GT42-7675R
2x44mm TIAL wastegates, 1bar springs
Custom made exhaust manifold in stainless steel.
4 Inch SS downpipe and midepipe
Garage Whifbitz 4" S/S Supra Exhaust Twin Box
Big KN air filter
Transmission
Clutch RPS Billet Carbon Triple Disc
V160 gearbox
Torsen LSD
TRD 6 Speed Gearbox Mount
3.5" driveshaftshop prop
2012 spec
It will be running on E85
Setup for the moment
Engine mangement Aem v1 for the moment
Trust intercooler
Wilsson intake 3,5
HKS fulrail
HKS DLI
Trust Turbo 78
Clutch RPS billet
Parts orderd
Titan Motorsports Dampend 2JZ-GTE Crank Pulley
Titan Motorsports 2JZ Cam Gears
Brian Crower 2JZGTE CAMSHAFTS Race 280
BC Springs and Retainers for the 2jz (B0300)
ARP Main Stud Kit For MKIV
Clevite 77 Engine Bearing Package for the 2JZ Supra
CP Pistons for Toyota Supra MK4 (20 over)
Brian Crower 2JZGE Sportsman Connecting Rods
Toyota OEM Supra MKIV (MK4) 2jza-gte Engine Gsket/Rebuild Kit
Greddy Timing belt
Running belt
Part to order
ARP L19
main caps??
Turbo
pictures from the pick up
the start of the project. Engine on the way out
so close....
Some part home
Edited by teddan
new spec! (see edit history)
  • Replies 134
Posted Images
  • 2 weeks later...
Parts under way to machine shop
Balance
Unfortunally the owner before mounted the new RPS clutch, and it seems like they have grinded the hole from paint so now we have a gap of 0,1mm on the axle :wtf:
. So we will make the hole bigger and fit a schim so it can be centred.
I bought aem control soleniod 30-2400. Do anyone knows if I can buyt a controller and gauge unit as well and connect it to? :rolleyes:
  • 2 months later...
Painted!
hmm I got a package :)
A really nice thing :) Jamie P old one
New bearings
I did not have any V-blocks so putted all the main bearings in. Maybe I just should put in the end bearings? My biggest runout was 0,025mm. Up to 0,06mm are OK
Then I mounted the thrust bearings
Just mounted the old main bearing bolts by hand
Thrust bearing check
Then just pull the crank up and zero the DTI and then putted the crank down. I got 0,11mm and manual accept between 0.020mm and 0.220mm. OK :)
This is my first engine built so I take huge amount of photos so if you see something wrong or something I forgot please write it :) Thanks
Edited by teddan (see edit history)
parachute brake seems to be a good ide ;)
No I did not read the terms I just thought it was NL01 ;)
For the moment the workload on my job is high so the progress with the car will be slow for a while.....
Nice that you like the thread :)
ARP for the main bearing in and fitting the main squirters
Checking the main clearance. Mine was in the upper level around 0,040mm. But I will leave it like this due to the high performance on this engine. Maximum allowed clearance is 0,060mm
I bought a scale to check the pistons. Amazing result. Check this.. pic heavy!
So next task is to set up the ring gap. Thinking of going in the dragracing class :)
