HELP/PLEASE ,,longer studs needed to fit gt,c wheels
Guest adam b
Guest adam b
Hi people ,i need some help please.
the studs on the new wheel hub are not long enough to go through the volk gtc wheels leaving no room for the nut.
Can some one let me know were to get some thats the right for the job,im sure other volk owners have had this problem..
cheers adam:D;)
Few options Adam, ARP do them, so do H&R (the guys that make the hubcentric spacers) and lastly your local alloy wheel shop (if you've got one) should too. They'll be in that order of expensiveness too. I'll have a look to see if I kept the piece of paper with the sizes I bought if you need it bud? I didn't fit volks but needed to replace the ones for my spacers.
Guest adam b
cheers lads.
its not the nuts ,but the bolt length.. ther to short ,ther standerd bolts all new with the hub from toyota,
iv looked at the old hub and ther the same length,so it must be the 18x10 fronts /18x11 rears have more depth to them,needing a longer bolt.??
the standerd oem bolt is about half a 3/4 inch to short
P3TE what size are your gtc,s mate..?
Guest adam b
i have gtc wheels on mine with normal studs? what type of wheel nut do you have? http://www.part-box.com/images/GT-CLNS.jpg these are the type needed
yes mate ther the nuts i have here,,
mybe its just me il get the nuts out in the morning and do a mock up with the new hub then il know for sure.
thay just look real short when the wheel is on the hub, but looking closer at the nuts ther long, thay fit deep so
its proberly just me .
cheers lads for the help il post up the out come tomorrow.
My spacers are 20mm hubcentrics, the extended bolts that I got from an alloy wheel shop (so they're probably available online from alloy places) were M12x1.5, DP 14 (spline diameter), and 70mm long. From memory they were around 3quid each.
Nice wheels btw bud :cool:
It's not just you. :eyebrows:
I've got the Volk GTC's and the same nuts as in the photo above. I had to fit longer studs as the stock ones weren't long enough. :rolleyes:
I can't remember where I bought them. :blink:
Guest adam b
as i thought meny thanks lads,,im gonna order some longer ones.:eyebrows:
i just googled and found a few places that do apr,s and some other good brands ,il post up my findings tomorrow..:D:d
