antno Posted April 18, 2012 Share Posted April 18, 2012 Just wondering what these connectors are for before re connecting them. i haven't unplug them just wanted to know if there was a reason behind why some one else has. had a look in the workshop manual but cant seem to find any info. cheers antno Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted April 18, 2012 Share Posted April 18, 2012 I'm not sure, but poss something to with the active spoiler? Does your car have one?? Someone knowledgeable will be along soon I'm sure... Quote Link to comment Share on other sites More sharing options...
antno Posted April 18, 2012 Author Share Posted April 18, 2012 I'm not sure, but poss something to with the active spoiler? Does your car have one?? Someone knowledgeable will be along soon I'm sure... doesn't now but may have done cheers antno Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 18, 2012 Share Posted April 18, 2012 Iirc they're the amp connectors for the Active Sound System. Quote Link to comment Share on other sites More sharing options...
antno Posted April 18, 2012 Author Share Posted April 18, 2012 Iirc they're the amp connectors for the Active Sound System. cheers pal. i take it the car has a built in amp somewhere. do you know if the amp was wired in through the std block connectors (2) or did it have a separate connection to the std head unit. just wondering if i fit my new head unit and connect those would the active sound system work? cheers antno Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 19, 2012 Share Posted April 19, 2012 cheers pal. i take it the car has a built in amp somewhere. do you know if the amp was wired in through the std block connectors (2) or did it have a separate connection to the std head unit. just wondering if i fit my new head unit and connect those would the active sound system work? cheers antno The amps under the passenger seat. If you're using the std. Toyota connectors that plug into the plugs you've pictured, then the active system won't work. Quote Link to comment Share on other sites More sharing options...
