Cheapest/bes place to drive in and out with a replacement engine supplied and fitted?
Guest Nurotix
Guest Nurotix
Hi guys,
Was wondering if anyone knows of somewhere or someone who keeps MK4 NA engines in stock or has one that would be able to do the work and possibly with some kind of warranty? It would just be a like-for-like direct swap with my engine that I'm after? Obviously want a known good engine going in, and turned around in the shortest amount of time possible. I don't mind travelling, as long as the price and reputation is right. I'm new to Supra's, so I really have no idea where to start calling around...
Thank you very much!! :)
Guest Nurotix
The head/head gasket is leaking exahust gas into the combustion chambers, however with the thermostat removed, I can drive it around without it overheating. I don't see the point in fixing this engine as it's on 200km, and it's probably cheaper/less hassle to get someone to stick a known working one in.
