Dan_Q Posted April 17, 2012 Share Posted April 17, 2012 Hi All, Bit of a nOOb question here- i've had a quick search but nothing came up- apologies if i've missed something obvious! I could do with fitting a pair of my 17" stock toyota rims to my supra soon. I've never had stock toyota rims on my supra yet and they didnt come with any nuts. My question is- are the wheel nuts the same shouldered fit as similar aged other toyotas? I have some Toyota nuts from sera EXY10 alloys, and from celica ST182/5 in the garage, and wondered if i could use them. These nuts have different heads but have the same 18.5mm diameter x 12.5mm long shank after the shoulder washer. Any help would be appreciated! I'm holding off having a spare pair of tyres fitted this week until I get an answer. Thanks for your time Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted April 17, 2012 Share Posted April 17, 2012 take a nut off the car and compare it with what you have in the garage. Then check them in the OE bolt holes to ensure they are the correct taper etc. Simples. Quote Link to comment Share on other sites More sharing options...
jonc Posted April 17, 2012 Share Posted April 17, 2012 I think I have 4 wheels worth of stock wheel nuts in the garage. I will have a look tomorrow and let you know. I know I had them before we moved house just got to hope I did not ditch them in the move Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted April 17, 2012 Author Share Posted April 17, 2012 take a nut off the car and compare it with what you have in the garage. Then check them in the OE bolt holes to ensure they are the correct taper etc. Simples. would do mate but it's only ever had aftermarkets on it in my ownership, so taper ones only on the car. I think I have 4 wheels worth of stock wheel nuts in the garage. I will have a look tomorrow and let you know. I know I had them before we moved house just got to hope I did not ditch them in the move cheers for that mate. if the ones i have won't do then i'll give you a shout cheers Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted April 19, 2012 Author Share Posted April 19, 2012 should be picking the wheels up early next week so i'll let y'all know if they fit or not, incase anyone asks the same in the future Quote Link to comment Share on other sites More sharing options...
jonc Posted April 20, 2012 Share Posted April 20, 2012 Balls, I forgot to look. I will look today and let you know about the nuts Quote Link to comment Share on other sites More sharing options...
