Graham1984 Posted April 17, 2012 Share Posted April 17, 2012 I have brought some ebay jobby side facelift indicators and I was wondering if they are just a straight swap as Paul Whiffin said a wire needs to be extended on one side, Is this only for the Toyota replacements or is it needed for all of them as I might nip out inbetween the rain and put them on if it is a quick job. I have the front facelift indicators too that I will trim the lug like in the guide and only use the one indicator to save buying a loom (Tight arse) is there anything else that I should watch out for when using the non loom method or is it just cut and fit for the existing bulb holder like it seems to be. Morning everyone as well. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 17, 2012 Author Share Posted April 17, 2012 Anyone have anything to offer?? Quote Link to comment Share on other sites More sharing options...
Noz Posted April 17, 2012 Share Posted April 17, 2012 I had to make up custom brackets to hold them in place. My wires were fine, so not sure if your need it though it shouldn't be a tricky job to extend them. Quote Link to comment Share on other sites More sharing options...
Ross C Posted April 17, 2012 Share Posted April 17, 2012 The side indicators should be a 2 second pry-out, switch bulbs and pop the new one in. I had mine done by L18msy and it was as simple as that Quote Link to comment Share on other sites More sharing options...
mr two Posted April 17, 2012 Share Posted April 17, 2012 as above.....couple of mins each side....no messing about with wires Quote Link to comment Share on other sites More sharing options...
Abz Posted April 17, 2012 Share Posted April 17, 2012 Are you talking about the pre facelift side indicator lights or the facelift front indicator lights? Quote Link to comment Share on other sites More sharing options...
Noz Posted April 17, 2012 Share Posted April 17, 2012 ooops sorry mate thought you meant the front ones doh Quote Link to comment Share on other sites More sharing options...
