Legal/Illegal number plate's
Guest ahamilton
If its an import your letters can be 64mm in hight with a 10mm spaces between each
Which in all fairness doesn't look all that bad
http://img12.imageshack.us/img12/4081/20120226145256.jpg
And if you don't want the BS code and the makers name to be visable have them make the text in white on the front and yellow on the back so it blends in with the number plate colour. There is no law stating what colour the text of the BS code and printers details have to be :)
Edited by a98pmalcolm (see edit history)
If it's an import your letters can be 64mm in height with a 10mm spaces between each...
Not strictly true. You can use the smaller plate with motorcycle-size font if the car's bodywork has a recess that is too small for the standard UK plate. That wouldn't apply in the example you posted.
Also, you'd probably have to argue the point with the magistrates if there was a "too small" mounting braket between the plate and the actual bodywork.
Edited by garethr (see edit history)
“Size and spacing of characters: special cases
14A.—(1) This regulation applies in relation to any vehicle imported into the United Kingdom which—
(a)does not have European Community Whole Vehicle Type Approval; and .
(b)is so constructed that the area available for the fixing of the registration plate precludes the display on the plate of a registration mark in conformity with the requirements of regulation 14. .
(2) In relation to a vehicle to which this regulation applies—
(a)each character in the registration mark must be 64 millimetres high; .
(b)the width of each character of the mark, other than the letter “I” and the figure “1”, must be 44 millimetres; .
©the width of every part of the stroke forming a character in a mark must be 10 millimetres; .
(d)the spacing between any two characters within a group must be 10 millimetres; .
(e)the vertical spacing between groups of characters must be 5 millimetres; .
(f)the width of a margin between the mark and the top and lateral sides of the registration plate must be not less than 5 millimetres; .
(g)the space between the bottom of the mark and the bottom of the registration plate must be not less than 13 millimetres; but, within that space, the space between the bottom of the mark and the top of the name and postcode of the person by whom the plate was supplied must be not less than 5 millimetres.”(1)
  • 1 month later...
Guest Harishsharma
I'm going to produce the rear as it is and change front back to the standard uk (ugly) size plate for the time being then take it from there I think! As a family run business, with a combined experience of nine years in the industry in replacing custom number plates. We supply number plates free with daily deliveries to all areas Uk, . New number plates may not be the most exciting purchase you have ever made but custom replacement plates but certainly will change the appearance of your vehicle.
premier-number-plates
