Why would my front Fogs not be working
DodgyRog
I have just brought my Supra home from it's winter sleep and for some reason the Front Fogs are not working
The Headlights have been put back in today, but I have checked the Fuse in the engine bay fuse box and it is fine, is there anything else it could be, just would be a bit odd if it's both bulbs at exactly the same time
I am useless when it comes to Electrics, especially random things
Any help appreciated, please explain in DumDum mode:blink:
fog lights only work when the side lights are on, he must of known that :O#
check the voltage on the lights when they are turned on. there is a small grey plastic clip that connects to the light, one of the pins are the positive for the fog lights. the side lights use the same earth wire. see if its triggering, if its not the bulb it will help you make sure its the system. then you can trace it further back the line.
Well it was the bulbs (well done Brendan) they look fine with the naked eye though. Odd for both to go at the same time,
but it gave me the kick up the bottom to fit the HID fogs I have had sat in the cupboard for about 2 years:rolleyes:
So I now have the full set of HID's with LED sidelight:cool:
