IanK Posted August 3, 2005 Share Posted August 3, 2005 The answer is VERY! Big thanks to Paul & the guys down at Whifbitz for all their work yesterday. Took my car there for a tune up as it was running very rich. We started off by removing the FCon V, but it still ran "off the scale" rich. Paul checked under my bonnet & it turns out that my car has bigger injectors fitted & coupled along with the HKS FCon & HKS Hipermax Drag suspension would point towards my car having Hybrid Turbos! They tuned the car to run at 1.2 bar for the moment with the SAFC, until I either get the FCon mapped or go down the E-Manage root. The car is so responsive now and has sooooooo much more pull than before. Also MPG has now shot up and the car no longer stinks of fuel! I am one very happy Whifbitz customer, thanks again Paul. Link to comment Share on other sites More sharing options...
Jake Posted August 3, 2005 Share Posted August 3, 2005 Glad you got the car runnig nicely. Must be a big relief. bigger injectors fitted & coupled along with the HKS FCon & HKS Hipermax Drag suspension would point towards my car having Hybrid Turbos! Would it? I don't follow the logic there. Can you elaborate please? Link to comment Share on other sites More sharing options...
IanK Posted August 3, 2005 Author Share Posted August 3, 2005 Would it? I don't follow the logic there. Can you elaborate please? I don't know a huge amount about these things so please excuse me but why would you got to the bother of bigger injectors & a FCon along with all the pipe work for stock twins? http://www.laserlines.com/supra2/engine.jpg Link to comment Share on other sites More sharing options...
Jake Posted August 3, 2005 Share Posted August 3, 2005 Well the stock JSpec injectors are maxed out at 1.2 bar so fitting bigger injectors does make sense if you're running higher than stock boost. The FCon V is presumably there to trim those injectors. Although it sounds like the FCon wasn't mapped correctly. I could be wrong but I've never heard of an jap Supra coming over here with hybrids already on it. Not trying to piss on your fireworks or anything Ian. Just wondering the reasoning for suspecting hybrids and trying to figure if it's likely. What's that thing coming off the pipe to the IC? (Between the airfilter and the rad) Link to comment Share on other sites More sharing options...
IanK Posted August 3, 2005 Author Share Posted August 3, 2005 Well the stock JSpec injectors are maxed out at 1.2 bar so fitting bigger injectors does make sense if you're running higher than stock boost. The FCon V is presumably there to trim those injectors. Although it sounds like the FCon wasn't mapped correctly. I could be wrong but I've never heard of an jap Supra coming over here with hybrids already on it. Not trying to piss on your fireworks or anything Ian. Just wondering the reasoning for suspecting hybrids and trying to figure if it's likely. No problem Jake, thanks for the info. We just thought it would have been a bit overkill but your theory also sounds very possible. unfortunately there is no easy way of now if the tubbies are stock without some serious labour. What's that thing coming off the pipe to the IC? (Between the airfilter and the rad) The BOV, not a great looker but it sounds great, nice wastegate style flutter at low boost release and nice loud psssssssst at high boost. Link to comment Share on other sites More sharing options...
terribleturner Posted August 3, 2005 Share Posted August 3, 2005 Bigger injectors Ian?? Nice, you know this means your on your way to going single Link to comment Share on other sites More sharing options...
IanK Posted August 3, 2005 Author Share Posted August 3, 2005 Bigger injectors Ian?? Nice, you know this means your on your way to going single Don't you start! Paul: "There's not much else you need to go singe!" yes there is, its called money! Link to comment Share on other sites More sharing options...
terribleturner Posted August 3, 2005 Share Posted August 3, 2005 Just get a loan Ian then VVVVVVVVVVVrrrrrrrrrrrrrooooooooooooooooommmmmmmmmmm Link to comment Share on other sites More sharing options...
IanK Posted August 3, 2005 Author Share Posted August 3, 2005 Just get a loan Ian then VVVVVVVVVVVrrrrrrrrrrrrrooooooooooooooooommmmmmmmmmm Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 3, 2005 Share Posted August 3, 2005 Don't you start! Paul: "There's not much else you need to go singe!" yes there is, its called money! You know it makes sense! Pleased your happier with your car now, still a lot more to come from it.... Link to comment Share on other sites More sharing options...
RobSheffield Posted August 3, 2005 Share Posted August 3, 2005 ok, a question this has raised, having just found an F con V i didnt know i had, what colour are stock injectors, would someone please post a picture? thanks Link to comment Share on other sites More sharing options...
Jake Posted August 3, 2005 Share Posted August 3, 2005 what colour are stock injectors VVTi = Pink J Spec = Grey UK Spec = Lilac Link to comment Share on other sites More sharing options...
Seb Posted August 3, 2005 Share Posted August 3, 2005 I spy twin air filters too, not seen that before! Link to comment Share on other sites More sharing options...
Jake Posted August 4, 2005 Share Posted August 4, 2005 Those headlights look in good shape too. Not yellowing at all. Link to comment Share on other sites More sharing options...
Supragal Posted August 4, 2005 Share Posted August 4, 2005 Sounds good. Link to comment Share on other sites More sharing options...
IanK Posted August 4, 2005 Author Share Posted August 4, 2005 Those headlights look in good shape too. Not yellowing at all. She's only done 25K miles! Link to comment Share on other sites More sharing options...
