drift_bear Posted April 12, 2012 Share Posted April 12, 2012 As some of you know i've replaced the supra with a lexus IS200 turbo, It's currently running an AEM piggy back along with the standard ECU. I'm looking at getting a new ECU tp replace this set-up and wondering what people recommend and prices of the unit and mapping. Any info would be great Alex Link to comment Share on other sites More sharing options...
Geo Posted April 12, 2012 Share Posted April 12, 2012 If Ryan could make up a loom for the Lexus then Syvecs all the way bud. simple as that, all that probably just over 2k Link to comment Share on other sites More sharing options...
drift_bear Posted April 12, 2012 Author Share Posted April 12, 2012 If Ryan could make up a loom for the Lexus then Syvecs all the way bud. simple as that, all that probably just over 2k I need to get something that will work with the HKS camp2 system aswell bud. Link to comment Share on other sites More sharing options...
johnny g Posted April 12, 2012 Share Posted April 12, 2012 What about the FCon Gold V? Link to comment Share on other sites More sharing options...
drift_bear Posted April 12, 2012 Author Share Posted April 12, 2012 What about the FCon Gold V? I cant seem to find any info out about a loom for the IS though, I know theres a couple on here for sale at the moment aswell. *EDIT* Just seen this on the whifbitz site, can get the syvecs S6 and wiring loom. Would that work with the HKS camp2 system though? Hmm the first syvecs powered IS200 turbo http://whifbitzperformancetuning.co.uk/nissan-pulsar-electronics-upgrades-c-24_33_251_451.html Link to comment Share on other sites More sharing options...
j_jza80 Posted April 12, 2012 Share Posted April 12, 2012 So long as your OBD2 port has full functionality, the Camp2 will work fine. But I'm sure Ryan would be able to connect it to the Syvecs. Link to comment Share on other sites More sharing options...
Wez Posted April 12, 2012 Share Posted April 12, 2012 Syvecs all the way Chat to Ryan about working with the HKS Camp2, it really depends where its getting the data from, looking on the HKS diagrams it would only get ECU data from an FCON so in theory swapping the ECU shouldnt be a prob. Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 12, 2012 Share Posted April 12, 2012 You will loose the A/C button and dash/clock functions as they are can bus. You have to retain the stock ecu to drive these systems. However, having two ecu's connected to the engine position sensors on this car seems to cause a misfire at 5k. Disconnecting the stock ecu from the engine position sensors stops the A/C button working. All a bit of an a5se really. I hacked a wire into the A/C button and used the Link G4 to switch the A/C compressor clutch when we did the 1G-GTE twin turbo conversion at Silverline, but that's another story . Lyndon. Link to comment Share on other sites More sharing options...
Wez Posted April 12, 2012 Share Posted April 12, 2012 Maybe the Syvecs could drive the CAN BUS devices using custom can profile, similar to what's been done on the GTR Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 12, 2012 Share Posted April 12, 2012 Maybe the Syvecs could drive the CAN BUS devices using custom can profile, similar to what's been done on the GTR Only with new firmware and can you see Mark at Life rewriting custom can stream software for one customer install? Lyndon. Link to comment Share on other sites More sharing options...
drift_bear Posted April 12, 2012 Author Share Posted April 12, 2012 All im needing to do is replace them AEM ecu or at least get it remapped if i can! When i put the footdown in the car it feels like im hitting fuel cut and lose boost, Has anyone got any experienmce with this ECU? Link to comment Share on other sites More sharing options...
Noz Posted April 12, 2012 Share Posted April 12, 2012 Whats your budget. That would be the main deciding factor. Link to comment Share on other sites More sharing options...
drift_bear Posted April 12, 2012 Author Share Posted April 12, 2012 I've not set a budget yet, I need an ecu that can ideally run with the camp2 system OR Keep the AEM and have that re-mapped so its better set up Link to comment Share on other sites More sharing options...
drift_bear Posted April 12, 2012 Author Share Posted April 12, 2012 Just been told that its an AEM FIC if that is any help to anyone and able to shine some light onto how good/easy to re-map or just sell on Link to comment Share on other sites More sharing options...
johnny g Posted April 12, 2012 Share Posted April 12, 2012 Just been told that its an AEM FIC if that is any help to anyone and able to shine some light onto how good/easy to re-map or just sell on Sell the F/IC and see about a Syvecs. Is the CAMP2 system important to you? If not, Syvecs + Toucan interface. Link to comment Share on other sites More sharing options...
sparkystav Posted April 14, 2012 Share Posted April 14, 2012 I cant seem to find any info out about a loom for the IS though, I know theres a couple on here for sale at the moment aswell. *EDIT* Just seen this on the whifbitz site, can get the syvecs S6 and wiring loom. Would that work with the HKS camp2 system though? Hmm the first syvecs powered IS200 turbo http://whifbitzperformancetuning.co.uk/nissan-pulsar-electronics-upgrades-c-24_33_251_451.html Sorry won't be the first, a lad on outlawjapclub club already has the syvecs installed on is turbo IS And the camp is pretty standalone isn't it so it shouldn't affect it Link to comment Share on other sites More sharing options...
sparkystav Posted April 14, 2012 Share Posted April 14, 2012 You will loose the A/C button and dash/clock functions as they are can bus. You have to retain the stock ecu to drive these systems. However, having two ecu's connected to the engine position sensors on this car seems to cause a misfire at 5k. Disconnecting the stock ecu from the engine position sensors stops the A/C button working. All a bit of an a5se really. I hacked a wire into the A/C button and used the Link G4 to switch the A/C compressor clutch when we did the 1G-GTE twin turbo conversion at Silverline, but that's another story . Lyndon. And an excellent job you did as well mate Though in the rebuild I'm doing at the moment I've removed the aircon completely lol along with the stock ecu Good to hear off you though. Link to comment Share on other sites More sharing options...
drift_bear Posted April 16, 2012 Author Share Posted April 16, 2012 Sell the F/IC and see about a Syvecs. Is the CAMP2 system important to you? If not, Syvecs + Toucan interface. Whats the toucan interface? Sorry won't be the first, a lad on outlawjapclub club already has the syvecs installed on is turbo IS And the camp is pretty standalone isn't it so it shouldn't affect it There goes that idea.... Link to comment Share on other sites More sharing options...
sparkystav Posted April 16, 2012 Share Posted April 16, 2012 Doesn't mean it's a bad idea though. Link to comment Share on other sites More sharing options...
drift_bear Posted April 16, 2012 Author Share Posted April 16, 2012 Can you pm me the thread/member? Wouldn't mind asking about the price of getting it done and etc Link to comment Share on other sites More sharing options...
