Swampy442 Posted April 12, 2012 Share Posted April 12, 2012 Not strictly mkiv tech but, my brother has an n/a Aristo and it's losing water. There's no obvious leaks anywhere and it does tend to pump quite a lot of condensation out of the exhausts, and when running there's a constant bubbling in the rad. But it runs like a dream, no emulsified oil. What sort of water consumption could I expect from a head gasket failure? Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 12, 2012 Share Posted April 12, 2012 Get a simple sniff test done and you'll know then if theres exhaust gases in the coolant. How much water is used with a failing headgasket is going to vary from a little if its just starting to fail to a lot if it properly lets go. Quote Link to comment Share on other sites More sharing options...
add heywood Posted April 12, 2012 Share Posted April 12, 2012 My headgasket went on my car (albeit a GTE), and would push coolant through the expansion tank on boost. Around town it was fine, no mayonaise and very little loss of water. Sniff test FTW Quote Link to comment Share on other sites More sharing options...
