having difficulty re-fitting air con pump (well just the bracket)
Lude
right so ive decided to re-fit the air con bracket, as withought one its making my fan belt screech.
so i got the bracket like this.....
i cant seem to get it to slot into place between the power steering bracket though?
heres a pic i drew, imagine as a birds eye view....
the red is the bracket for the power steering pump, and the blue is the new air con bracket
should just slot in nice and easy...
however inside the bracket for the power steering pump, there is something in the way? looks like its suposed to be there, but its proventing the air con bracket slipping in nicely?
do i just need to get underneath the car and hammer the air con bracket in?
or the part ive drawn in green has that come out of the power steering bracket hole and need to be pressed back?
ah i get you. i was trying to wiggle it back using the aircon bracket.
so it needs sliding back the same way you push brake pistons back.
maul grips or just a thin bar i asume should do it. thanks guys :-)
