IDO Posted April 10, 2012 Share Posted April 10, 2012 anyone have a crank for a TT engine? (sorry don't know if i need a specific one or if they are generic?) Any info would be great thanks.. Ian Link to comment Share on other sites More sharing options...
mellonman Posted April 10, 2012 Share Posted April 10, 2012 the n/a and the tt are the same crank Link to comment Share on other sites More sharing options...
IDO Posted April 10, 2012 Author Share Posted April 10, 2012 the n/a and the tt are the same crank Thanks, thought that was the case, but with my luck with the car at the mo' if there was different types I would have got the wrong one!! ta for the Info.. Link to comment Share on other sites More sharing options...
mellonman Posted April 10, 2012 Share Posted April 10, 2012 yeah but now you still have to find one lol Link to comment Share on other sites More sharing options...
themodifiedkid Posted April 10, 2012 Share Posted April 10, 2012 Pm The Raven, he will have 1 as he is breaking his engine Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 11, 2012 Share Posted April 11, 2012 I would try and buy a short N/A engine, or a full N/A engine and strip it yourself. cranks don't travel or store well unless great care is taken. A slight mark on a journal, or any rust renders it either scrap or needing a regrind. You need to have a used one checked for straightness, ovality and size before using it. I always get used cranks micro polished by someone that knows how to do it properly and won't cause rear main bearing seal oil leaks. (If you have a bad payer you can polish a crank in such a way as it always weeps oil at the main rear oil seal and / or the front seal, and they'll probably NEVER find out why ) Link to comment Share on other sites More sharing options...
IDO Posted April 11, 2012 Author Share Posted April 11, 2012 Think i've managed to get a Full N/A engine... Thanks for the heads up people.. Thanks Chris for the warning, The garage who is fixing my car uses a place that seem to have a v.good rep for sorting and polishing cranks( they were looking at my old one and found a slight bend and a crack) but i will mention to the garage about looking out for the bearing seal leaks... Many thanks all Ian Link to comment Share on other sites More sharing options...
