MattP Posted April 9, 2012 Share Posted April 9, 2012 Hi guys well how to start since buying a 94 N/A Auto a couple of months ago I have slowly been making progress at rectifying bits and pieces the previous owner neglected to mention one of the problems that has been bothering me from day one, and that would be the autobox on the car has a loud whine in first and when the car becomes stationary I have gradually over the past few months had smoke coming from the auto shifter (I currently have the dash panels and centre box out making the smoke more noticable) when I have checked under the bonnet the smoke appears to be coming from the back of the engine where the gearbox joins. Any Ideas on what could cause this Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted April 9, 2012 Share Posted April 9, 2012 (edited) This could be connected to your other problem Check your Cam Cover bolts are tight, they only need to be nipped up, not wrenched They have a habit of working loose and it's possible oil is leaking down to the spark plugs (which would be causing your misfire) as well as down the back of the engine onto the gearbox Edited April 9, 2012 by DodgyRog (see edit history) Quote Link to comment Share on other sites More sharing options...
MattP Posted April 9, 2012 Author Share Posted April 9, 2012 Ahhhhhhhhhhhhhh I did notice an unusual amount of oil in the spark plug area this could be the problem il pull the car in and get this intake off. The oil could interfere with the plugs if enough gets in there is this correct? Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted April 9, 2012 Share Posted April 9, 2012 Sounds like this is definately your problem I suggest you take the throttle body off and then you can get proper access and see properly with a torch From the problems you have I would put money on the cam covers being loose, do a search, it's a common issue Not sure on the 1st gear whine though Quote Link to comment Share on other sites More sharing options...
MattP Posted April 9, 2012 Author Share Posted April 9, 2012 had a look underneath looks like its deffo the gearbox leaking oil from somewhere Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 9, 2012 Share Posted April 9, 2012 had a look underneath looks like its deffo the gearbox leaking oil from somewhere Rear crank seal? are you 100% sure its from the box as i thought mine had the same problem with a leak but it was the rocker gasket. The oil then runs down the back of the block onto the top of the box, and dribbles down giving the appearance the box is leaking. The same thing can happen if the nuts are not tightened as rog said. Quote Link to comment Share on other sites More sharing options...
MattP Posted April 9, 2012 Author Share Posted April 9, 2012 Il have a better look in daylight tommorow and report back but from taking the intake apart and pulling the plugs etc I cant see any way its leaking Quote Link to comment Share on other sites More sharing options...
David P Posted April 9, 2012 Share Posted April 9, 2012 If you need a box to fix the whine. http://www.mkivsupra.net/vbb/showthread.php?250118-N-A-auto-transmission Quote Link to comment Share on other sites More sharing options...
