R154 questions
Giiioo
It's not the power which kills them, it's torque and how you use it. I.e road 800hp no probs, drag and drift you could smash a thrust washer with only 300hp.
Iv smashed 4 washers, broken various hubs, rings, selectors and even totally shredded 2nd gear off of the shaft with less than 650hp, but that's drift with loads of traction.
No stronger really, as it's shock loading that brakes the washer. Even the uprated washers still can't take a hole load of abuse. The stock ones are too tough and this makes them brittle, uprated washers are not so brittle but wear out faster due to the properties.
