RSE TRD Supra with an X2K conversion and RHD to LHD conversion
x2k.dk
  • Replies 127
actually kinda sad. it looks good on the pics but some lines dont fit on th car it self. and i found a little hole ( my bad :) didnt get all the air out of the fiberglas work).
some pics
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0235.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0225.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0226.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0227.jpg
The Big Boss accepting the rest of the paintwork
thats my son by the way
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0231.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0232.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0233.jpg
Well guys. still waiting for the painter to get his finger out and finish the car it self .
so until then i thought i would polish my wheels abit just to see if i could do it or if i wheels company should try doing something to them.
but using Autosol worked perfect.
have a look totally suprised how nice they became.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0317.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0318.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0319.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0320.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0321.jpg
After that i decided to do some engine loom work.
i need to hide most of it and turn it to LHD aswell.
im also later moving the fuse box and all that you see. clean look is the way
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0322.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0323.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0324.jpg
alone the engine loom took me 2 days. alot of checking to make sure all wires are welded hot and 100 leading.
thank god for test equipment
this is what i used for the wheels
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0326.jpg
and my loom tools-
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0328.jpg
  • 3 weeks later...
Back to the project again :)
i got another engine home , with a single turbo , its easier to registrate (MOT they call it in UK ) Tüv in germany.
here is the spec list from when it was build .
Brand new Toyota Short Block
Brian Crower Rods
ARP rod bolts
ARP Head bolts
ARP Head Studs
Polished and Ported Head
Titanium Retainers
Uprated springs and Valves
HKS 272 IN and 272 EX Cams
HKS Cam Pulleys
Brand new oil pump and water pump April 08
New coil packs
NEw Plugs
TRD oil cap
RPS Streetmax clutch
LSD
New Battery in boot on PHR holder
AEM ECU with 3 bar map sensor
Ross Racing Fuel rail
Siemens 890cc injectors
Braided fuel lines
Aeromotive FPR
Aero motive In line race fuel filter
Twin Walbro pumps
New tank to FPR lines
AEM AFR Gauge
Boostlogic T67DBB Single Turbo
Boostlogic Manifold
HKS Type R Intercooler
HKS Wastegate
HKS Oil cooler
HKS Oil filter relocation kit
Aftermarket screamer pipe
Custom made downpipe
Veilside Ti Exhaust
Fluidyne radiator
Fluidyne twin polished electric fans with overide switch
Polished Intake, rad pipe, turbo
Polished power steering and brake caps
Polished billet powersteering pump and braided oil lines
Polished cam covers, water injection tank, HKS catch tank
Polished radiator overflow tank, engine bay sills, door sills
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20ARP%20Head%20bolts.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20CIMG2160.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20boostlogic%20BL_TT_Manifold.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20brand%20new%20toyota%20block%20with%20pistons%20in%2008.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20d%20HKS%20272%20IN%20and%20272%20EX%20Cams.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20f%20HKS%20Cam%20Pulleys.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20g%20Ross%20Racing%20Fuel%20rail.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20h%20Siemens%20890cc%20injectors.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0382%20i%20Titanium%20Retainers.jpg
and the parts starting to go in ------
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0387.jpg
polished ABS and colored the plastik.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0388.jpg
master cylinders colored and fitted¨
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0390.jpg
wastegate rebuild . goes back into the exhaust. for MOT reasons.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0392.jpg
HKS Suspension
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0395.jpg
HKS Catch can polished and ready to install.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0397.jpg
installed the new Fuel system with braided lines and so on.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0400.jpg
LHD steering rack ready to go
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0401.jpg
and i need a brake now :)
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0695.jpg
Can't look !, too painful lol
i know how you feel. i would do the same if some one took my baby appart. but no worries. the rest will be in perfect condition ;) and ill drive it everyday .
i am only a little bit envious of you good sir :)
:p
back on track .
clutch
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0406.jpg
engine getting cleaned. colored parts and different parts polished.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0412.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0413.jpg
i tricked this guy believing that he would get 3 wishes if he continued polishing :)
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0415.jpg
back to the loom work. makes you insane. .
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0417.jpg
and some fun stuff.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0419.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0421.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0422.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0423.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0426.jpg
some more polished .
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0429.jpg
NEW coilpacks. just got them today.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0430.jpg
bought some bushings for the gearbox. had problems getting it in gear. now it works perfect.
hoses changed in the engine aswell. they get hard with time.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0431.jpg
My friend Allan heling me polish most of the parts.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0432.jpg
and the sexy result . :) damn looks good. sex on wheels :)
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0695%20motor.JPG
Looks great! Have you painted the intake!?
tanx mate.
yes its painted. it was chromed but i didnt like it.
Congrats on the build, its going to be special by the way this build is going..! :)
yeah im taking it all the way ;)
