RSE TRD Supra with an X2K conversion and RHD to LHD conversion
x2k.dk
yup guys.
just to start this i got my self a Supra from UK and im about to rebuild it and convert it into LHD.
And before you start "u crazy why do you convert into lhd" well its not easy driving a lhd country with a rhd car. and difficult to program my brain to shift gears with my left hand. allmost impossible with all that power without misshifting and destroying the box.
here is the spec list from the day i got it.
Toyota Supra Big Twin Turbo
HRE - front 10 x 19 rear 12 x 19 made to custom specification
Pirelli - 355/25/19 rears - 275/30/19 fronts
Cusco roll cage
HKS 60mm Boost gauge
HKS 60mm EGT Gauge
HKS 60mm Oil pressure gauge
HKS 60mm Oil temp gauge
HKS 60mm Water temp gauge
momo gearstick
Re leathering of interior rear seats and all panels by Stratstone
Sabelt 4 way harnesses
Sparco Milano black leather seats
Steering wheel and boss
JUN Racing wing
Rage Illusion - green/purple flip paint
Total cost inc labour and vat
TRD Wide body
AP Racing 6 pots 356mm cross drilled fronts
Braided brake lines
Cross drilled rear discs with ferodo pads
HKS Hypermax II Coilovers
TRD Front and Rear anti roll bars
-10 SX fuel filter
-6 to -4 vac. pipe collector
1800cc injectors
1mm oversized stainless steel valves
2 x -4 fuel lines to nitrous solenoids
2 x 3" downpipes
2 x 4" air intakes
2 x Innovative GT66 Ballbearing Turbos with custom spec internals
2 x Tial BOV's
3 x Walbro fuel pumps
3" exhaust dump with boost control
4" exhaust system
6" deep Custom intercooler
AEM CDi ignition module
AEM ECU
AEM Injector driver
ARP Main studs
Crower rods
Custom 100mm throttle body
Custom 4" intercooler pipework
Custom oil catch tank with 2 x -10 breathers
Custom tubular manifold
Custom Virtual works inlet manifold
dash 10 fuel lines
dash 10 fuel rail
dash 6 return
Direct port progressively and ECU controlled Nitrous oxide system
Double valve springs
Fluidyne Alloy intercooler
full pipework wiggens clamps
Greddy Auxillary pulleys
Greddy uprated cambelt
HKS 272 cams
HKS 2mm head gasket
HKS Knock monitor
HKS Oil cooler
HKS Spark plugs
HKS Verniers
J E Pistons
Polished and ported head
Race liners
Racelogic traction control
SX fuel reg
Tial wastegate
Titan crank pulley
Titanium retainers and caps
Total parts in excess of
Uprated head studs
Uprated main bearings
here some starting pics
Edited by x2k.dk (see edit history)
  • Replies 127
Parts to remove. since im doing a LHD conversion. and sell to UK maybe :)
And bodykit to repair. unbelieveable that they used normal window glue to build the trd kit.
anyways. all goes off and back on with correct glue and fiber glas matts with polyester. everything had cracked
removing brakes
sell it to me and convert another supra :p majorly agree with the colour change! what you thinking of spraying it mate?
nahh TRD is my favourit Kit . so im keeping this one ...... engine will be changed . since i need something more "driveable" for everyday.
All RHD interiour parts are out. just waiting for parts from USA .
thanks to the following supra forum memebers for all the parts.
Marcos Myrie
94Singledout
turbodragnovice
x-1
Kurt
Supra97er
Engine and ABS system out.
NEW PARTS from toyota CURT USA
just found out that brake pedal setup and clutch pedal setup isnt that expensive new by CURt- actually cheaper then what people sell them in the supra forum used.
and something My diff will be happy about :)
RHD to LHD conversion makes sense, especially when it is this wide and powerful!
Looking forward to seeing the colour change, any idea's on what colour you are going to go for?
well i do LOVE my other White Supra . especially the color ;) so its pulling me that direction :)
here a pic of the old one.
http://x2k.dk/images/Supra%20single%20LHD%20Eurospec/5.jpg
http://x2k.dk/images/Supra%20single%20LHD%20Eurospec/8.jpg
[ATTACH=CONFIG]149632[/ATTACH]
Not that I am biased but I'd say white too! :D
Looks lovely your other Supra :cool:
Next is getting ready like my friend does :)
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0150.jpg
next i glued the rear fenders correctly. and not with flexible glue like before but with 2 komponent glue. next is glasfiber reinforcement.
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0152.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0153.jpg
New hood lifters. the LHD firewall went in and wiper motor mounts changed to fit a lhd wiper instead
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0154.jpg
http://x2k.dk/images/TRD%20X2k%20RSE%20supra/IMAG0155.jpg
