Giiioo Posted April 8, 2012 Share Posted April 8, 2012 what is the real power limit on w58? is it good for 400whp bpu 2jz? Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted April 8, 2012 Share Posted April 8, 2012 no..doubt it would last long Quote Link to comment Share on other sites More sharing options...
Mario Posted April 8, 2012 Share Posted April 8, 2012 Round about 350whp. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 8, 2012 Share Posted April 8, 2012 Hp isn't the issue though, it's the torque. Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted April 8, 2012 Share Posted April 8, 2012 More to do with the torque, I'm sure there are a few bpu cars running the w58, but they don't hang on for long! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 8, 2012 Share Posted April 8, 2012 I would hazard a guess at just over 400ft/lb for reliability. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 8, 2012 Share Posted April 8, 2012 while we are on the same kind of subject how much can the r154 handle? Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 i have mk3 r154 but need bits to swap. anyway how much power r154 holds? is it good for 550whp? i know trust washer is issue on them but on what hp they brake? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 8, 2012 Share Posted April 8, 2012 ive been told that its stronger than the w58 so im thinking of doing that but depends how much it costs because if its not much more i may aswell go 6 speed Quote Link to comment Share on other sites More sharing options...
David P Posted April 8, 2012 Share Posted April 8, 2012 trust washer See it as you say it. Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 is r154 ok for 550whp without change trust washer? Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted April 8, 2012 Share Posted April 8, 2012 ive seen r154 holding 800+bhp its a strong 5 speed! Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 if washer changed they hold 900+ but need info how strong box with stock washer Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 8, 2012 Share Posted April 8, 2012 550 whp is over 600 real hp, but once again you missed the point, its the torque that kills boxes not power. Depending on what youre doing with it. If youre pulling skidz and clutch kicking it, drag starts etc it wont last long but treated with a but of sympathy 600hp should be OK. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 8, 2012 Share Posted April 8, 2012 its torque that kills boxes. 350lbs of torque and lots of off the line drag launches will soon lunch a w58 ,im running around 500lbs ft on my mk3 r154 now ,lets see how long it lasts Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 Is your r154 stock? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 8, 2012 Share Posted April 8, 2012 yea. the 154 is a strong box, the thrust washer will only suffer if the box is abused. my car is a circuit car. belive it or not, circuit racing is not too hard on the boxes. all the shifts are at pace so ther is minimal straing or load put through the shafts, where as drag launches put mega loads on the components Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 8, 2012 Share Posted April 8, 2012 whats the rough cost of parts for the 154 conversion from a autobox? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 8, 2012 Share Posted April 8, 2012 whats the rough cost of parts for the 154 conversion from a autobox? I sold a conversion less clutch and flywheel for 1100 quid last year. It was box from a Chaser so it had the cradle shifter extension. Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 I need bellhousing and flywheel, Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted April 8, 2012 Share Posted April 8, 2012 I did NA to TT conversion for a friend and he used the w58 and is running BPU, the box is still fine as far as i no. Quote Link to comment Share on other sites More sharing options...
Giiioo Posted April 8, 2012 Author Share Posted April 8, 2012 My car is same, 400 hp on flywheel and box is fine but i want change ecu and power will be about 475 on flywheel. I think it's not safe for w58 Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 8, 2012 Share Posted April 8, 2012 I would hazard a guess at just over 400ft/lb for reliability. Out of interest would sort of bhp would that equate too? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 8, 2012 Share Posted April 8, 2012 Out of interest would sort of bhp would that equate too? you couldnt really say mate. some engines can make huge bhp with much less torque where as some engines can make mountains of torque with a relitively low peak bhp. bhp is just what the engine peaks at , torque is the engines twisting power , thats what does the job Quote Link to comment Share on other sites More sharing options...
Noz Posted April 8, 2012 Share Posted April 8, 2012 depends on the set up graham. from what ive seen, bigger turbo's produce more torque at the same bhp (rare you see bigger turbo's producing the same power as smaller turbos, all depends on the setup). you normally see more bhp with less torque with turbo applications. so somewhere between 400-450bhp for example. if it was a supercharger, it would probably have 300-450bhp due to the delivery, as super charging is more focused on torque. diesel engines are different due to the way the fuel explodes rather than ignites, you get engines with 220bhp with 400+ ft/lb. Quote Link to comment Share on other sites More sharing options...
