a way to stop it starting :)
ashbuster
The kill switch Idea is very easy. There is a wire that signals the Igniter to fire the coil. Splice a switch into that and you will have ignition kill and the beauty of it is there is another wire that tells the ecu not to open the injectors in the event of failed ignition. This way you get ignition and fuel cut with one switch ;)
This is for an NA... Not sure if a TT has a similar setup or not but if you find the wiring diagram for the ign then it should be simple to work out ;)
In all honesty though, if own a supra you should really own and alarm and immobiliser...
