AEM AFR gauge
D8MOA
when you buy a new kit it comes with gauge and sensor probe...
when fitting to a UK spec does it wire into the 2nd prob and render the AEM probe usless? or do i have to wirein the AEM probe and render the uk 2nd probe usless?
You can only use the sensor it comes with to run the gauge as it is wide-band, the std sensor is narrow-band, you can configure the AEM to output a simulated narrow-band output to feed the ECU with, however, its a pain and not overly reliable IMO.
I would leave the std sensor be and just weld in another boss for the AEM.
