Jake Posted August 2, 2005 Share Posted August 2, 2005 Do you really undo the top bell housing bolts from under the car? I can't even see them from underneath let alone get to them! What am I doing wrong? Do I have to drop the rear of the gearbox or something like that? I can just about see the top bolts from above but they look very difficult to undo with a spanner from there. There's no way I could get a socket on them from above. (1998 RZS Auto/Tiptronic, by the way) Thanks Quote Link to comment Share on other sites More sharing options...
baldy Posted August 2, 2005 Share Posted August 2, 2005 jake a long extension bar 30 inch i think,go over the top of the box from the prop mount,a good torch is a big help have fun i did!! Quote Link to comment Share on other sites More sharing options...
secondjump Posted August 2, 2005 Share Posted August 2, 2005 I have the same problem regarding the install of my tc.....Mig says a stubby spanner and mighty two finger leaverage does the job but i reckon he must have bionic fingers - although this is with a single were there is a little bit more room to play with. Good luck mate Quote Link to comment Share on other sites More sharing options...
Jake Posted August 2, 2005 Author Share Posted August 2, 2005 Sod it, I'll have to take the engine out with the gearbox still attached. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 2, 2005 Share Posted August 2, 2005 Underneath, a long wobble extension, or pair of fairly long 1/2 inch drive extensions, the socket most end having a wobble feature and a 17 mm socket. Easy... It really is, some cars are FAR FAR more of a PITA to get the engine out of. lots of FWD cars for example, Skylines blah blah. Quote Link to comment Share on other sites More sharing options...
