Dim Sum Posted May 6, 2012 Author Share Posted May 6, 2012 bov is fine checked that. going to check all the vacuum lines tomorrow. 1st turbo boosts to 0.6 bar but 2nd turbo doesn't kick in at all. Don't mean to scare you but i've found out the cause to my fault in the supra, might not be the same but. I dropped it off to Paul at Garage Whifbitz to find the fault and when he finally found it he told me something as hit the first turbo and damage the blade but the second turbo is fine. Here is my symptoms: - 1st turbo boosts to 0.6 bar, 0.68 bar not second turbo - No smoke or rattle - Sounds like a leak - BOV work fine If you have check everything maybe worth having the turbo looked. Better check to make sure then drive it around making it worst. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 6, 2012 Share Posted May 6, 2012 Mine has just done this today, no unsual noises, 1st turbo kicks in, showing 0.68 on boost gauge, but no 2nd turbo. Put it in ttc mode, if you get full boost it's a sequential control rather than a turbo issue. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 6, 2012 Share Posted May 6, 2012 will try this later on cheers. I reckon its a vacuum leak somewhere it was fine yesterday running really well the all of a sudden just lost 2nd turbo. hose spilt or popped i reckon Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 6, 2012 Share Posted May 6, 2012 will try this later on cheers. I reckon its a vacuum leak somewhere it was fine yesterday running really well the all of a sudden just lost 2nd turbo. hose spilt or popped i reckon lose of second turbo is normaly caused by the vsv at the top back of the engine,check the vac pipes to that Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 6, 2012 Share Posted May 6, 2012 thanks mate got a length of hose so will renew those and go from there Quote Link to comment Share on other sites More sharing options...
