Nic Posted April 6, 2012 Share Posted April 6, 2012 Anyone removed the stock retractable aerial and replaced with a small fixed 'beesting' type aerial in the same location? Link to comment Share on other sites More sharing options...
Westy Posted April 6, 2012 Share Posted April 6, 2012 I've done the S2000 aerial swap. Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2012 Share Posted April 6, 2012 As above, use 'search' dude Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2012 Author Share Posted April 6, 2012 I've done the S2000 aerial swap. Cheers for that As above, use 'search' dude Oh that's what that button does Link to comment Share on other sites More sharing options...
RA28 Posted April 6, 2012 Share Posted April 6, 2012 The previous owner of mine had fitted a simple Euro style beesting aerial. Link to comment Share on other sites More sharing options...
jim Posted April 6, 2012 Share Posted April 6, 2012 Why you ask Nic, you need pics or opinions or prices bud? Link to comment Share on other sites More sharing options...
Guigsy Posted April 6, 2012 Share Posted April 6, 2012 I have one but the reception where I live isn't great with it. I'm putting a normal one in my new car as it has none atm Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 6, 2012 Share Posted April 6, 2012 I've also done the S2000 swap, easy to do, looks good but the reception isnt brilliant. Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2012 Author Share Posted April 6, 2012 Why you ask Nic, you need pics or opinions or prices bud? The mast on my MR2 is knackered and when it is raised looks stupidly long for the size of the car. The aerial is mounted on the rear wing similar to the Supra, looks like the S2000 aerial should fit okay. Next question where did you source the S2000 aerial assembly from? Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2012 Author Share Posted April 6, 2012 (edited) I have one but the reception where I live isn't great with it. I'm putting a normal one in my new car as it has none atm Do you have the complete aerial assembly fitted including the signal amplifier box? Edited April 6, 2012 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Abz Posted April 6, 2012 Share Posted April 6, 2012 As above, use 'search' dude You are asking an ex trader who joined in 2001 with 20k of posts to use the search button? I am also interested in this, my stock Ariel has died. Link to comment Share on other sites More sharing options...
supraturbochris Posted April 6, 2012 Share Posted April 6, 2012 Nic. a s2000 ariel on the mr2 would look lovely. do miss the noise of that nur spec. :-) Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2012 Share Posted April 6, 2012 You are asking an ex trader who joined in 2001 with 20k of posts to use the search button? Yes. It was tongue in cheek. As everyone has said, the stubbies ruin the reception, even in London it isn't too great. Looks brilliant though. I'm going to have to look into a way of boosting the reception somehow. Link to comment Share on other sites More sharing options...
Abz Posted April 6, 2012 Share Posted April 6, 2012 Yes. It was tongue in cheek. As everyone has said, the stubbies ruin the reception, even in London it isn't too great. Looks brilliant though. I'm going to have to look into a way of boosting the reception somehow. I am playing too Would be interested if you find a fix, I sometimes listen to LBC. Link to comment Share on other sites More sharing options...
Lee P Posted April 6, 2012 Share Posted April 6, 2012 To be honest Nic you can fit the shorter stubby aerials but the reception will never be as good as the stock one. If you can live with that then its fine, not sure if it will be as bad on the MR2 but on the supra it's not great. Link to comment Share on other sites More sharing options...
JamieP Posted April 6, 2012 Share Posted April 6, 2012 As others have said, i have the S2000 stubby and reception is bad. Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2012 Author Share Posted April 6, 2012 Thanks guys. Any other OEM car aerials or aftermarket aerials that'd fit? Anyone tried a signal booster with their S2000 aerial? For those that have fitted one, how much did you pay? Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2012 Share Posted April 6, 2012 I know Abz, its all fun dude. Has anyone ever fitted one of the rear window aerials, when you use the actual window as the aerial itself? They are on some higher end cars out of the factory. Link to comment Share on other sites More sharing options...
Abz Posted April 6, 2012 Share Posted April 6, 2012 I know Abz, its all fun dude. Has anyone ever fitted one of the rear window aerials, when you use the actual window as the aerial itself? They are on some higher end cars out of the factory. Thought the Supra had a rear window ariel too? Remember imi mentioning it in some thread? Stevo organised the previous S2000 GB, I think. Gaz, did you get yours from the GB? Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2012 Share Posted April 6, 2012 I did, its a really good bit of kit, fit really easily, I bet Stevo could throw another one together for the OP. Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2012 Author Share Posted April 6, 2012 Found the group buy thread, it looks like the gb was just for the aerial mast not the complete assembly including the OEM signal amplifier. Has anyone fitted the complete aerial assembly and can comment on the reception quality? http://a248.e.akamai.net/origin-cdn.volusion.com/tsreo.wqzzj/v/vspfiles/photos/39150-S2A-A01-2.jpg?1320929885 Link to comment Share on other sites More sharing options...
Guest suprageek Posted April 6, 2012 Share Posted April 6, 2012 I've a wanted ad up on here looking for a stubby s2000 Aries, I take it I could just buy it from honda, would it need anything diff to fit on the supra? Link to comment Share on other sites More sharing options...
LOGIE Posted April 6, 2012 Share Posted April 6, 2012 I feel much better now knowing that im not the only one with a s**t reception with my stubby aerial, @ suprageek as for buying from honda i think it will be mega ££. I sourced one online from a scrappy about a year ago and they wanted £90 needless to say i never bought it. Link to comment Share on other sites More sharing options...
LOGIE Posted April 6, 2012 Share Posted April 6, 2012 Found the group buy thread, it looks like the gb was just for the aerial mast not the complete assembly including the OEM signal amplifier. Has anyone fitted the complete aerial assembly and can comment on the reception quality? http://a248.e.akamai.net/origin-cdn.volusion.com/tsreo.wqzzj/v/vspfiles/photos/39150-S2A-A01-2.jpg?1320929885 Certainly looks the part, id be interested in one of these too if anyone has any info on how good they are. Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2012 Share Posted April 6, 2012 As above, interested in that. Link to comment Share on other sites More sharing options...
