Pictures of how the soopy is looking atm
Supra N_A
well after done bpu removed the active spoiler(fmic in place) also disconnected the ecu so that was that joby done also the red (!) sign was on the dash but removed the ECU and job done!
whilst I was taken that ecu out bought a new cd player as the other was poop.. lovley jubley ;)
its running a 100% perfect atm love it just NEED bigger brakes asap as the j spec brakes are just no good for bpu power, have a nice set in mind :eyebrows:
:eyebrows:
couple new parts getting fitted next week :ecstatic:
Guest suprageek
my car is bpu i have jspec brakes i recetly changed the pads to ebc redstuff and bled the whole brake system and replaced the brake fluid with dot 5.1 and i have to say the car stops really really well, i suppose it depends on discs and pads etc, i have chris wilson drilled and grooved discs.
JSpec's will always stop you first time from 170mph to a dead stop... just don't do it again so soon! :D
With decent pads\discs\fluids\braided lines they are fairly good, though not a patch on the larger brake setup.
you say bigger tyres JP?? what size would you go with as there 19s?
Width, in all your pictures the rears look seriously stretched on the wheel and very low profile, a tyre that fits the rim better will look and perform far better.
