The 'proper' way of deleting the air con pump
Parry_10
Really bugging me now just been out to have another look and it looks like behind the air con pulley there is some bolts that bolt that bracket part (that supports the power steering pump) to the air con pump. It would be easy to check if someone has a pump off the car or even if you go and have a look at your air con pump you will understand what im saying more.
I have one on my shelf' date=' took it off last night. Does look like you can remove the pulley, and there are Allen head bolts underneath. What lurks after is an unknown![/quote']
Yeh thats what I thought mate, that front section of the pump is not sealed to the actual pump it unbolts so in theory you could just remove the pulley and leave that part in place which is what supports the power steering pump, and remove the actual air con pump and system. Im so sure of it but not going to say for definate until ive done it myself.
Dam I think I chucked my air con pump away , how easy is it to make a bracket ?
In theory its easy to make a bracket yes but if it will be good enough who knows? id imagine alot of engineering and tests went into making that air con bracket on the front of the air con pump. If I was you I would just find another air con pump.
i ran my car for about 6 months without a bracket.
now i have a screetching noise from the belt, asif its slipping.
ive made a bracket, but its still doing the screetching noise.
going to put a bracket on like this.....
as my bracket attaches higher up above the crank pulley so to speak
Parry10 just thought I would let you know that your theory is right! I have just looked at my supra workshop manuals and you can indeed take the bracket of the front of the AC compressor so there will be no need to make a bracket you can just use that.
Paul372 has just confirmed my theory that the front part of the air con pump unbolts from the rest of the pump. So id say the best way to do it is to use this as a bracket as this is the part that is used to support the power steering pump. Obviously at your own risk but this is what im going to be doing I dont see there being any problems doing it this way.
  • 3 weeks later...
  • 3 months later...
