wile e coyote Posted April 3, 2012 Share Posted April 3, 2012 Well i spent 6 hrs last night replacing all my lower wishbones. Had to cut all but 2 bolts out what a nightmare. Luckily i had use of a ramp etc. If anybody else does this make sure they purchase all bolts and washers as i did Quote Link to comment Share on other sites More sharing options...
D8MOA Posted April 3, 2012 Share Posted April 3, 2012 I'm in the process of striping mine out and I no these bolts will cause issues lol Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 3, 2012 Share Posted April 3, 2012 They seize inside the bush and can be a right job to get out, cutting with a disc can sometimes be the only option. I wouldn't entertain doing this without having the use of a ramp and dont forget you'll need a full geo set up afterwards Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 3, 2012 Author Share Posted April 3, 2012 The geo is all booked for sat:thumbup: Quote Link to comment Share on other sites More sharing options...
SteveR Posted April 3, 2012 Share Posted April 3, 2012 How come you only did the lower ones? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 3, 2012 Author Share Posted April 3, 2012 Tried to do geo a few weeks ago and all seized.The rear uppers were done about 3 years ago and could not afford to do upper fronts yet all the lowers plus bolts etc came to 1600 Quote Link to comment Share on other sites More sharing options...
SteveR Posted April 3, 2012 Share Posted April 3, 2012 Yeah I know it's not cheap* - didn't realise you'd done the uppers already. * = entered into the "understatement of 2012" competition category. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 3, 2012 Share Posted April 3, 2012 It should drive really well once done though, and will be good for a long time. Just make sure you get all those new bolts protected On the plus side, the price could be worse. I've heard that the spherical suspension arms on the Honda NSX total at around £10k! Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 3, 2012 Author Share Posted April 3, 2012 Holy cow Yeh all copper greased up Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 Geo all done this morning Drives nice and true now but the bloody rds down here are not great and having 295 tyres on the rear don't help If anybody in the SW wants there's done i have negotiated a price of £65 plus vat for the club but that's as long as the bolts are not seized Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 7, 2012 Share Posted April 7, 2012 Supprised your not running a bit more camber on the front, stock is -0.5 degrees Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 I really don't understand the readings mate Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 7, 2012 Share Posted April 7, 2012 A bit more negative camber on the fronts will help with grip in the corners, obviously the more you run the more you wear out the inner edge of the tyre Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 been for a drive this after noon and car feels loose now thought it was funny cambers in the rd If i do a quick pull sharp left it seems to wobble feeling unsafe If i do a quick pull sharp right it feels ok Any body any ideas The car is a 1997/ 98 supra tt vvti Quote Link to comment Share on other sites More sharing options...
SteveR Posted April 7, 2012 Share Posted April 7, 2012 corner weighting is an essential part of geo, imho - did you get that done? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 Don't think so don't even know how thats done mate The system they use is the new hunter Checked tyre preasures they seem ok Really hope the god mr wilson reads this as I need this done for dragonball Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 Im going to remove all wheels tomorrow and check all nuts bolts inc sub frame. Does the readings seem ok or are they wrong ? I can see me being up all night now thinking about it Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 7, 2012 Share Posted April 7, 2012 The geo figures are pretty close to mine apart from im running -1 degree of camber on the front. Who set up your Teins ? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 7, 2012 Author Share Posted April 7, 2012 I fitted them and came from same car wheels did. Was all good till I fitted new arms and had geo done Rear tyres second hand 4mm pirele rosso fitted before also Quote Link to comment Share on other sites More sharing options...
dude Posted April 8, 2012 Share Posted April 8, 2012 You need more camber on the fronts and also about 1mm toe in, it will make the car more stable at high speed, that geo is rubbish, which is prob why it cost £65, I would not even put it on the ramp for that !!! Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 8, 2012 Author Share Posted April 8, 2012 You need more camber on the fronts and also about 1mm toe in, it will make the car more stable at high speed, that geo is rubbish, which is prob why it cost £65, I would not even put it on the ramp for that !!! Dude how much will you charge me knowing the bolts are are free Would like to get it sorted for dragonball I know it was cheap but its got it to a driverble state Ok all done i found the rear passenger toe bar nut loose on the ball joint so i had rear steer like a skyline lol Lesson learnt dont do these things when tired it was the last one we did monday evening at midnight You have permision to shoot me down it could have ended in tears I am surprised the guy doing the geo did not spot it Thanks guys Quote Link to comment Share on other sites More sharing options...
dude Posted April 8, 2012 Share Posted April 8, 2012 Ask him to put more camber in and a little bit of toe (1mm) if he altered the rear toe its him who did not do up the nut !!! Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 8, 2012 Author Share Posted April 8, 2012 ok mate it was the nut on the ball joint which i guesed would not have touched that extra you say is for rear or front ? Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 8, 2012 Share Posted April 8, 2012 He wouldn't undo the ball joint so thats down to you mate (tut tut ) Just to add my car drives great and i'll post up my figures as im sure im not running much toe on the front or the rear but definitely more camber Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 8, 2012 Share Posted April 8, 2012 (edited) My car has rear camber is -1 degree 50 minutes total rear toe is 0 degree 30 minutes front camber is -1 degree front castor is 4 degrees total front toe is 0 degree 10 minutes Edited April 8, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
