pjavon Posted April 2, 2012 Share Posted April 2, 2012 Does anyone know where the positive injector wires go from 6 into 1 on a 2JZ GE so I can wire the resistor pack in. I thought I'd found it but when I've looked closer there is only 4 wires going into one (black and Orange). The black and orange are the positive ones and right by where the loom goes through the bulkhead they do loop together into one but theres only 4 wires going into the 1 and not 6! I'm a bit lost now as I can't see how this would be right but the looms never been apart before so obviously it is. Any help please Quote Link to comment Share on other sites More sharing options...
heckler Posted April 2, 2012 Share Posted April 2, 2012 Does anyone know where the positive injector wires go from 6 into 1 on a 2JZ GE so I can wire the resistor pack in. I thought I'd found it but when I've looked closer there is only 4 wires going into one (black and Orange). The black and orange are the positive ones and right by where the loom goes through the bulkhead they do loop together into one but theres only 4 wires going into the 1 and not 6! I'm a bit lost now as I can't see how this would be right but the looms never been apart before so obviously it is. Any help please As far as I am aware, that part of the loom is the same as the GTE. So... the orange/black wire does indeed eventually go into just the one power feed within the bulk head area. Not sure if you read my guide http://www.internetwork.org.uk/mechanical/Injectors/Injectors.? You may find that the 4 go into 1, that then the other two join another futher along - probably with in the flexible part of the loom. I've fitted a couple of resistor packs now, and they have been a bit like you described - but I've never had a problem! Quote Link to comment Share on other sites More sharing options...
pjavon Posted April 2, 2012 Author Share Posted April 2, 2012 Thanks, I'll have a look. Your links not working for me mate? Quote Link to comment Share on other sites More sharing options...
heckler Posted April 2, 2012 Share Posted April 2, 2012 Thanks, I'll have a look. Your links not working for me mate? doh. thy this... http://www.internetwork.org.uk/mechanical/Injectors/Injectors.htm Quote Link to comment Share on other sites More sharing options...
