Another Boost leak i think thread........
Dim Sum
I did a search and some were useful and some information i read, i already knew so i was wondering if i could get a fresh insight from the forum on this matter :)
Okay today i took the stock airbox pipe out the one connecting from the airbox to the turbo pipe
After putting it back on it won't boost over 0.65 of boost, at first i thought it must be that pipe that i took off and thought i didn't tighten it enough so got back and tighten it again and same thing happened.
The turbo sounds like its spooling and very loud then pressure seems to leak i think. But the dump valve goes off
I did noticed that a bit of rubber on the hose was chipped off but would that cause the leak?
This part is end 65mm end that connects to the pipe turbo.
