NA Auto cooling.
Colin-mkiv
I have an NA Auto and as most of you will know, the bottom of the radiator on these cars is the oil cooler for the transmission.
I am looking to uprate the cooling on my car and fit electric fans, I don't trust the viscous fan at all and removing that and the air-con from an NA should improve throttle response a little bit.
I am aware of the power steering bracket issues associated with the aircon removal, but what pitfalls am I likely to encounter in the fitting of an aluminium radiator intended for a TT and fitting a separate transmission oil cooler in where the standard IC would go on a TT?
Cooling would be via 2 x 12" or (similar sized) fans fitted in a custom shroud on the rear of the rad and would be switched via a sensor plumbed into the top radiator hose.
I would also be looking to fit a more accurate temp gauge in the cockpit.
All suggestions and advice gratefully received. Cheers. :)
The viscous fans fail by stiffening ie their failure results in over cooling a kind of failsafe design. If you pop the bonnet and yours moves fine by hand it is ok, if it's stiff/won't move then the fan is seized and obviously not ok! A siezed fan will/should have made itself known before now by the noise and possibly poor idle.
Edited by Scooter (see edit history)
