loose brake rotor
costas1
hi fellas..i removed the wheels today and noticed that my front brake discs are a bit loose.i could move them back and front.i am not talking beetween disc and bell looseness .the disc including the bell can move. the brakes are brembo gran turismo.
is this normal?
p.s for the last 6 months the steering wheel will shake massively when trying to brake at a speed of 60+.
is this what causing it?
The bell can't move as its sandwiched between the hub and the
wheel once the wheel is fitted and torqued up.
Are yours fully floating as the Gran Turismo set i've just read about are
so the disc will move on the bell.
If they are then you need to take them off to check them.
Edited by Dnk
re read the op's post lol (see edit history)
Your problem is the discs out of true -they need skimming on car , and make sure that mating surfaces are super clean .
bolt the disc on with the wheel off - then spin the disc and measure between disc surface and caliper - you can use a simple matchstick just to see if the disc is true
there are no retaining screws with the brembo set up ,the wheel bolts hold them in place.
Assuming the bells are the correct supra fitment
the discs are not moving when the wheels are on.they are only moving when the wheels are off.yes the brembo set up is designed so that the bell moves a little between the bell and the disc.i was asking about movement between bell-disc and the car hub when the wheels are off.
jagman..the last two garages i went they also told me that the discs needed skimming.so we took them off and took them to the lathe.since then the problem is getting worse.and the funny thing about that is that the discs were new when they told me that they need to be skinned.
so now nobdy knows what is going on
the discs came new .i do not know if anybody ckecked them at the garage.(how do you check new discs?).and no i did not send them back because after installation they were used so i thought i can not send them back.
yes the steering shakes massively only when i push the brakes and at speeds everything over 60
With a fully floating disc i'd remove the disc from the bell and check both parts seperately, could be done
on a surface plate with a DTI or set up on a CNM machine or put on a lathe and checked with a DTI or
on a milling machine etc etc.
I'd simply use a micrometer first to check the disc was actually parallel on its thickness then carry out
further test to see if it or the bell is warped or even been made out of true.
i think at the machinery garage the technician put the bell also on the lahte and did some work in the inner diameter of the bell.maybe he skinned some material and that's why is now loose from the car hub. i was thinking of putting metal rings to hold the bell tight on the car hub.(just like the ones we put on the aftermarket rims).
would that be safe and correct to fix my problem.will i have any problems with the rings considering the heat is being generated in these spots?
They have to be skimmed on car - and the hubs as clean as you can get before fitting the bells ,any dirt rust etc can throw them out , almost all judder problems are discs un parrallel ,barring the obvious caliper loose
I have Brembo BBK and they needed a skim - to take up hub error ,only a couple of thou out and you get judder - skimmed on car now perfect -nice brakes by the way ,great progressive braking
so now what do i have to do? first check again the discs and the bells if they are wrapped.then clean the car hub .what about the disc-bell looseness?how about yours?is the disc-bell loose when you take off the wheel?can you move them front and back while the caliper is still on tightened?
what about the rings idea?
I have never skimmed a disc on the car in all my years in motorsport and engineering
and have always ground discs on a cylindrical grinder and never had a problem.
If theres a problem with the hub being out or buckled then i'd be fixing that rather
than masking the problem.
