Blackie Posted March 29, 2012 Share Posted March 29, 2012 (edited) I have noticed when i come off boost, Right off the throttle to basically rolling i notice quite a lot of white smoke behind me. I also noticed that the Supra seemed abit "Lumpy" while it was happing, Now a trusted mate has told me its most lightly my turbo seals but im wondering if there could be any chance of a plug fouling? (Before i go getting new turbos) Ive seen it happen three times in the past two weeks of driving it quite quick so its not every single time. Ive recently gone full bpu so maybe they have poo'ed themselves? Edited March 29, 2012 by Blackie (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 29, 2012 Share Posted March 29, 2012 When the throttle is shut there is no fuel getting injected, so that rules that out, I would also say turbo, as I believe rings/valve stem seals produce blue smoke? Do you have any smoke on hot idle mate? My Saab turbo also does this (apparantly but Ive never seen it) Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted March 29, 2012 Share Posted March 29, 2012 turbo seals mate, i have the exact same problem, let it idle for a while, should puff out then . thats why im ordering my single turbo lol. Quote Link to comment Share on other sites More sharing options...
Blackie Posted March 29, 2012 Author Share Posted March 29, 2012 When the throttle is shut there is no fuel getting injected, so that rules that out, I would also say turbo, as I believe rings/valve stem seals produce blue smoke? Do you have any smoke on hot idle mate? My Saab turbo also does this (apparantly but Ive never seen it) No smoke on idle or start up, It only happens at speed and its not a regular thing Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted March 29, 2012 Share Posted March 29, 2012 oh, then its no the turbo seals , ( i think), i only get it when i come to a stop/idle. when im going, no white smoke appears with me.. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 29, 2012 Share Posted March 29, 2012 What oil are you using? Quote Link to comment Share on other sites More sharing options...
Blackie Posted March 29, 2012 Author Share Posted March 29, 2012 What oil are you using? Cant remember, not cheap stuff. its got darker but not black? oh, then its no the turbo seals , ( i think), i only get it when i come to a stop/idle. when im going, no white smoke appears with me.. Yours isnt the turbo seals or mine isnt? lol Quote Link to comment Share on other sites More sharing options...
Abz Posted March 29, 2012 Share Posted March 29, 2012 I *think* it is value stems, I had my cats taken out and apparently that triggers it to be worse. Something along them lines. You 100% sure it is white smoke? thought white smoke = water\condensation. Blue = Oil Black = Unburnt fuel\Turbo's. Quote Link to comment Share on other sites More sharing options...
Blackie Posted March 29, 2012 Author Share Posted March 29, 2012 I *think* it is value stems, I had my cats taken out and apparently that triggers it to be worse. Something along them lines. You 100% sure it is white smoke? thought white smoke = water\condensation. Blue = Oil Black = Unburnt fuel\Turbo's. It was deff white, I had Karolina looking out for it too to make sure Quote Link to comment Share on other sites More sharing options...
Littler Posted March 29, 2012 Share Posted March 29, 2012 I'm another one to say it sounds like the valve stem seals. Quote Link to comment Share on other sites More sharing options...
Blackie Posted March 29, 2012 Author Share Posted March 29, 2012 I'm another one to say it sounds like the valve stem seals. It doesnt do it on tick over though? And not offen Quote Link to comment Share on other sites More sharing options...
Abz Posted March 29, 2012 Share Posted March 29, 2012 It doesnt do it on tick over though? And not offen How often do you drive your Supra Blackie? Because mine wouldn't blow out white smoke on start up unless I left it for a week or so. Even then the smoke was fairly low. Seemed to get worse on hot days when I had wafts of white smoke go past, again it was occasionally. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted March 29, 2012 Share Posted March 29, 2012 Valve stem seals only show on start up as far as I know. Mine do. Unless they are totally shot the amount of oil getting into the cylinder would be tiny. The reason for smoke on start up is due to an accumulation when switched off. Never had an issue with smoke whilst driving, but can get quite a lot if the car has been sat for a few weeks without use. I thought lift off smoke was generally diagnosed as turbo seals. I'm sure someone will be along soon to say for certain. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 29, 2012 Share Posted March 29, 2012 I mentioned oil because it its less than 40w its quite light and can bypass worn turbo oil seals, sometimes upping the weight to a 50 cures problems like that. A Soarer I had smoked quite nicely using Mobil 1 0w 40. Quote Link to comment Share on other sites More sharing options...
jcbt Posted March 29, 2012 Share Posted March 29, 2012 My valve stem seal problem showed up in two ways. The first was blue smoke on start up and occasionally pulling away after idling for some time e.g. bad traffic. I never got any smoke coming off throttle so I doubt the problem highlighted is VSM related. As said somebody will no doubt be along to point you in the right direction Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted March 29, 2012 Share Posted March 29, 2012 The stem seals are gone on my Porsche (non turbo) and this generally is worst on start up, but also shows on over-run pulling up at lights etc, its a blue coloured smoke though. White vapour is usually steam and seams to dissipate really quickly. Quote Link to comment Share on other sites More sharing options...
