What tyres and wheel width
mattdavies
I am about to uprgrade my wheels on my supra, the previous owner has put 18x7.5 on front and back. the new wheels i have are 18x10 and 18x8.5.
Just wondered what is the standard tyre size from factory and what size tyres would you recommend for my new wheels ?
Rim width---Min tyre width----Ideal tyre width-------Max tyre width
7.0 inches-----195 mm--------205 or 215 mm-----------225 mm
7.5 inches-----205 mm--------215 or 225 mm-----------235 mm
8.0 inches-----215 mm--------225 or 235 mm-----------245 mm
8.5 inches-----225 mm--------235 or 245 mm-----------255 mm
9,0 inches-----235 mm--------245 or 255 mm-----------265 mm
9.5 inches-----245 mm--------255 or 265 mm-----------275 mm
10.0 inches----255 mm--------265 or 275 mm-----------285 mm
10.5 inches----265 mm--------275 or 285 mm-----------295 mm
11.0 inches----275 mm--------285 or 295 mm-----------305 mm
11.5 inches----285 mm--------295 or 305 mm-----------315 mm
12.0 inches----295 mm--------305 or 315 mm-----------325 mm
12.5 inches----305 mm--------315 or 325 mm-----------335 mm
hope this helps.
These are the stock sizes for the 16" and 17" wheels
Front 225 50 16
Rear 245 45 16
Front 235 45 17
Rear 255 40 17
You should use the tyre calculators to get the correct profile to keep the rolling
radius close to o/e, http://www.etyres.co.uk/tyre-size-calculator.htm
Also heres a good offset calculator
http://www.1010tires.com/wheeloffsetcalculator.asp
All very useful. i have been using a sit called willtheyfit.com , only issue with this is that it sometimes redirects you to dodgy sites which is annoying as it is a useful tool.
edit: i have just looked at the two site you uploaded links for, and will they fit combines both of the sites and also gives you a readout of speedo error at 60 + 30mph
Edited by mattdavies (see edit history)
