Whats the 0 to 60 on this NA-T?
Noz
Guest MikeyTT
I'd say that pulled pretty well to 60mph, I'm sure it would keep accelerating at the same rate, which is what these cars are all about!
Start to loose traction in first so changed. I timed it around 5 seconds when I catch the video just right with a stop watch. Problem is, it should be sub 5 seconds with what Im running, trying to keep it around 4k it just feels bogged down. Too much negitive camber is reducing traction, need to have a few more runs I think. Need to try my slicks out..
Thought Id ask you guys first, as I don't want to say what I think I got, I'd rather say what the general idea seems to be.
So you think the gearing is too short? Maybe worth looking into then. I know jekyl put a TT auto diff in to give a longer ratio for each gear, hitting 70mph in 2nd. would it be an idea to rev to 7200 instead of 6800, so the turbo is in boost more? I'd like an R154 in the next few months, I expect that's a similar ratio
You dumped the clutch in first gear at 4,000rpm, of course you are going to loose traction! :p
Maybe do a longer video? Start without a hard launch.
