Mugello Posted March 27, 2012 Share Posted March 27, 2012 Hey all, First of all would like to say i purchased my first supra today Its a 3.0L Twin Turbo Auto Nice all round car just needs a little TLC. So, after reading and searching a lot about the forum for speedo related problems im still not much clearer. I should explain mine is j-spec but has been converted to mph and miles (odo). And the problem, the speedo (mph) isn’t working (all other gauges work fine) so where to go from here ? Im a wear that mine has a small box behind the dash (speedo) to convert the km to mph which has probly come lose. But anything else it could be ? Possibly a fuse ? Speedo cable ? Any info is great P.S. - Be kind im new Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 27, 2012 Share Posted March 27, 2012 Hi, welcome to the club. The Speedo could be a couple of things, you are going to need to pop the dash off and have a look at connections for the Speedo connector, it is probably loose somewhere, or the unit is caputz. To be honest it is all easily fixed as long as you are happy to get a screwdriver out. If you search for hecklers dash removal thread and for a thread for fitting speedo converter you will be able to see how it all comes apart, and more importantly goes back together! Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 27, 2012 Author Share Posted March 27, 2012 Hi, welcome to the club. The Speedo could be a couple of things, you are going to need to pop the dash off and have a look at connections for the Speedo connector, it is probably loose somewhere, or the unit is caputz. To be honest it is all easily fixed as long as you are happy to get a screwdriver out. If you search for hecklers dash removal thread and for a thread for fitting speedo converter you will be able to see how it all comes apart, and more importantly goes back together! Thanks im glad to be apart of the club Wanted in for years Right i see, well im going to remove all dash panels tomorrow and look for lose connection/not wired wires and see what i find. No chance of it being a fuse then ? Quote Link to comment Share on other sites More sharing options...
Konrad Posted March 27, 2012 Share Posted March 27, 2012 It's rather unlikely. I would put my money on faulty km/h mph converter Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 28, 2012 Author Share Posted March 28, 2012 It's rather unlikely. I would put my money on faulty km/h mph converter I see.... Well i removed all the dash today and here are some pics of what i found. This is the current converter box (black thing) http://img99.imageshack.us/img99/6617/20120328115039.jpg All the wires are connected but this pink one below is from the odo plug and is cut and goes nowhere ????? Is this normal ?? http://img576.imageshack.us/img576/9339/20120328115111.jpg And here is the back of the speedo.... http://img706.imageshack.us/img706/2137/20120328115024.jpg As always any help is great ! Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 28, 2012 Author Share Posted March 28, 2012 Also if it is the converter that needs replacing can someone link me up ? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 28, 2012 Share Posted March 28, 2012 Wiring looks ok, the white connector in the second photo looks like the one that is supposed to be plugged into the back of the odometer. If all the connections are secure and the wire connections are good then I would talk to Jurgen at jm imports for a convertor, whatever he uses seems to work well. I would to be safe, remove the whole dial cluster (taking photos of what goes where), check the soldering on the back is ok, sometimes it gets a bit rusty, clean what needs cleaning and then re-assemble, it could be something minor and I would want to make sure before getting out the wallet. Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 28, 2012 Author Share Posted March 28, 2012 Wiring looks ok, the white connector in the second photo looks like the one that is supposed to be plugged into the back of the odometer. If all the connections are secure and the wire connections are good then I would talk to Jurgen at jm imports for a convertor, whatever he uses seems to work well. I would to be safe, remove the whole dial cluster (taking photos of what goes where), check the soldering on the back is ok, sometimes it gets a bit rusty, clean what needs cleaning and then re-assemble, it could be something minor and I would want to make sure before getting out the wallet. Yes that is correct, what about the pink wire coming from it that has been cut and just left ??? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 28, 2012 Share Posted March 28, 2012 The pink wire..... Mmm. No idea mate, i think mine is connected. Put a connection in you can plug in and pull out easily and see what it does. Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 28, 2012 Author Share Posted March 28, 2012 The pink wire..... Mmm. No idea mate, i think mine is connected. Put a connection in you can plug in and pull out easily and see what it does. Tbh it does seem odd that its not connected to anything..... I also dont understand the last part above :/ Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 28, 2012 Author Share Posted March 28, 2012 From my research i think the pink wire does need to be cut, maybe yours is cut futher back mate Infact if you look in that second pic you can see the pink wire joining another wire So.... UPDATE !!! I will check all other wiring and joints tomorrow, and providing there all good its more than likely a faulty converter..... Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 28, 2012 Share Posted March 28, 2012 I had a look today, pink wire needs to be cut. Seems your convertor is fubar. Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 29, 2012 Author Share Posted March 29, 2012 I had a look today, pink wire needs to be cut. Seems your convertor is fubar. Thanks for checking buddy, im grateful for that !! Looks like i best order a new one Quote Link to comment Share on other sites More sharing options...
