HID question (end of life?)
Matt H
SOLVED - INSTALLED A HID RELAY
I've had my HIDs for a while now and wondered if the passenger side bulb needs replacing or whether it's something more sinister, like the ballast?
The passenger side usually lights up when I first turn the car over, but quite quickly turns off and won't come back on. Is this the way HID bulbs behave at the end of their life? (normal fillament bulbs just die and that's it), or could the problem be something else?
Just thought I'd ask before ordering new bulbs only to find I need a new ballast or something.
Thanks,
Matt
Edited by Matt H (see edit history)
Probably a bad earth/poor connection somewhere, the ballasts need a certain voltage to fire up the HID bulbs, a low voltage can cause flickering or the bulb not to light at all. Try swapping the bulbs over and see if the problem stays on the same side.
You could try connecting the ballasts up directly to the battery and see if they work okay. Connecting the ballasts up with a relay directly to the battery will ensure they work properly, do a search on Ebay for 'HID relay'.
I'd recommend this too Matt if they are firing up.
Never had one go on me, but I'd imagine they would be like the filament bulbs and just not work.
  • 1 month later...
  • 2 years later...
Just bringing this back up, I bought my HIDS on the group buy back in 2012 a think it was. Now my HIDS are playing up,they have been like this for a while now basically one side will turn off while am driving, I then turn them off and back on and they stay on! Then sometimes they don't go off. Its really random it can be either side and sometimes both. :blink: any help appreciated. Cheers
This was the group buy by dan
http://www.mkivsupra.net/vbb/showthread.php?277323-Group-Buy-on-HIDs&highlight=Hids+problem
