JMB Posted March 26, 2012 Share Posted March 26, 2012 I read lots of things and I am not sure to understand so: here is a picture of the plate I hope it's a torsen as I read this one is very good..or else I'll have to do some purchase Quote Link to comment Share on other sites More sharing options...
garethr Posted March 26, 2012 Share Posted March 26, 2012 The "B" at the end of A02B means that the car was fitted with a factory Torsen LSD. Quote Link to comment Share on other sites More sharing options...
JMB Posted March 26, 2012 Author Share Posted March 26, 2012 Cool Thanks, I read lot s of thing for aftermarket LSD, and most of the time peoples told me to keep this one... Quote Link to comment Share on other sites More sharing options...
ellis Posted March 26, 2012 Share Posted March 26, 2012 Bonus! Just checked mine and it's AO2B as well. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted March 26, 2012 Share Posted March 26, 2012 I'll have to check mine now! Quote Link to comment Share on other sites More sharing options...
cooke Posted April 5, 2012 Share Posted April 5, 2012 if i have a supra with no lsd how do i find out what one i need, i have a 93 supra non turbo Quote Link to comment Share on other sites More sharing options...
James Posted April 5, 2012 Share Posted April 5, 2012 A02B means: A - Crown wheel size of 8" 02 - 3.769:1 diff ratio B - Torsen LSD Quote Link to comment Share on other sites More sharing options...
cooke Posted April 5, 2012 Share Posted April 5, 2012 but if i dont have a lsd on my supra will it still say on the plate a02b or the other one to let me know which one to buy, its a 93 non turbo auto Quote Link to comment Share on other sites More sharing options...
James Posted April 5, 2012 Share Posted April 5, 2012 The plate code corresponds to what you have. Most NA auto cars have the code A01A as they have the smaller casing (the first A represents this), the diff ratio of 4.083 (the 01 represents this) and an open diff (the last A represents this). If you were wanting to fit an LSD, the factory option which was available for the NA auto was a Torsen LSD with the 4.083:1 ratio. This would make your code A01B (optional on the prefacelift SZ). The only NA which came with the 3.769:1 diff was the 6 speed SZ-R (facelift model). Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 5, 2012 Share Posted April 5, 2012 basiclt if it ends in A its open if it ends in B it torsen lsd Quote Link to comment Share on other sites More sharing options...
James Posted April 5, 2012 Share Posted April 5, 2012 basiclt if it ends in A its open if it ends in B it torsen lsd Yep, further to that, if it says 01 then it is 4.083:1 diff ratio, if it says 02 then it is 3.769:1 and if it says 03 then it is 3.267:1. If it starts with an A then it is small case (8" crown wheel size) and if it starts with B it is big case (8.7"). Quote Link to comment Share on other sites More sharing options...
cooke Posted April 5, 2012 Share Posted April 5, 2012 Rite were can i get a b casing Quote Link to comment Share on other sites More sharing options...
Supra Kong Posted April 5, 2012 Share Posted April 5, 2012 Stupid question then, what are the advantages of a big or small case? Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted April 5, 2012 Share Posted April 5, 2012 Oooh I have a B03B! Thanks for the explanation Quote Link to comment Share on other sites More sharing options...
David P Posted April 6, 2012 Share Posted April 6, 2012 Supra Torsen differentials. N/A 4AT 4.083 A01B N/A 5MT 4.083 A01B N/A 6MT 3.769 A02B T.T. 4AT 3.769 A02B T.T. 6MT 3.266 A03B U.K. 6MT 3.133 B03B Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted April 6, 2012 Share Posted April 6, 2012 Supra Torsen differentials. N/A 4AT 4.083 A01B N/A 5MT 4.083 A01B N/A 6MT 3.769 A02B T.T. 4AT 3.769 A02B T.T. 6MT 3.266 A03B U.K. 6MT 3.133 B03B Mine is a j spec though with a B03B how does that work? Or does the U.K not stand for uk? Quote Link to comment Share on other sites More sharing options...
David P Posted April 6, 2012 Share Posted April 6, 2012 That information except U.K. spec came from here. http://mkiv.supras.org.nz/specs.htm But there are some 'differences', more info here. http://www.mkivsupra.net/vbb/showthread.php?266839-searching-list-of-differnential Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted April 6, 2012 Share Posted April 6, 2012 That information except U.K. spec came from here. http://mkiv.supras.org.nz/specs.htm But there are some 'differences', more info here. http://www.mkivsupra.net/vbb/showthread.php?266839-searching-list-of-differnential Thanks mate very helpful Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 6, 2012 Share Posted April 6, 2012 Supra Torsen differentials. N/A 4AT 4.083 A01B N/A 5MT 4.083 A01B N/A 6MT 3.769 A02B T.T. 4AT 3.769 A02B T.T. 6MT 3.266 A03B U.K. 6MT 3.133 B03B Don't forget A05B, which is a USDM 4.273 with Torsen LSD. I have one. Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted April 6, 2012 Share Posted April 6, 2012 A02B on my 98 6spd NA Quote Link to comment Share on other sites More sharing options...
David P Posted April 6, 2012 Share Posted April 6, 2012 Supra Torsen differentials. N/A 4AT 4.083 A01B N/A 5MT 4.083 A01B N/A 6MT 3.769 A02B T.T. 4AT 3.769 A02B T.T. 6MT 3.266 A03B USDM ? 4.273 A05B U.K. 6MT 3.133 B03B What engine/transmission is with your AO5B? Anyone with any other codes for the record? Quote Link to comment Share on other sites More sharing options...
DJT88 Posted April 6, 2012 Share Posted April 6, 2012 My jspec TT is also a B03B with a V160 (6MT) Quote Link to comment Share on other sites More sharing options...
David P Posted April 6, 2012 Share Posted April 6, 2012 Are these J spec B03B's 3.266 or 3.133? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 6, 2012 Share Posted April 6, 2012 What engine/transmission is with your A05B? W58, 5 speed manual. I'm nearly sure thats the correct model number for the diff, it actually came from a USDM Lexus SC300 but the USDM NA Supra had the same diff for a couple of years. Quote Link to comment Share on other sites More sharing options...
David P Posted April 6, 2012 Share Posted April 6, 2012 (edited) Supra Torsen differentials. Jap N/A 4AT 4.083 A01B Jap N/A 5MT 4.083 A01B Jap N/A 6MT 3.769 A02B Jap T.T. 4AT 3.769 A02B Jap T.T. 6MT 3.266 A03B - 3.??? B303B U.S. N/A 4AT U.S. N/A 5MT 4.273 A05B U.S. N/A 6MT U.S. T.T 4AT U.S. T.T. 6MT U.K. T.T. 6MT 3.133 B03B U.K. T.T. 4AT Anyone with any other codes/ratios for the record? Edited April 6, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
