What LSD do I have ?
JMB
  • 2 weeks later...
The plate code corresponds to what you have.
Most NA auto cars have the code A01A as they have the smaller casing (the first A represents this), the diff ratio of 4.083 (the 01 represents this) and an open diff (the last A represents this). If you were wanting to fit an LSD, the factory option which was available for the NA auto was a Torsen LSD with the 4.083:1 ratio. This would make your code A01B (optional on the prefacelift SZ).
The only NA which came with the 3.769:1 diff was the 6 speed SZ-R (facelift model).
basiclt if it ends in A its open if it ends in B it torsen lsd
Yep, further to that, if it says 01 then it is 4.083:1 diff ratio, if it says 02 then it is 3.769:1 and if it says 03 then it is 3.267:1.
If it starts with an A then it is small case (8" crown wheel size) and if it starts with B it is big case (8.7").
Supra Torsen differentials.
N/A 4AT 4.083 A01B
N/A 5MT 4.083 A01B
N/A 6MT 3.769 A02B
T.T. 4AT 3.769 A02B
T.T. 6MT 3.266 A03B
USDM ? 4.273 A05B
U.K. 6MT 3.133 B03B
What engine/transmission is with your AO5B?
Anyone with any other codes for the record?
Jap N/A 4AT 4.083 A01B
Jap N/A 5MT 4.083 A01B
Jap N/A 6MT 3.769 A02B
Jap T.T. 4AT 3.769 A02B
Jap T.T. 6MT 3.266 A03B - 3.??? B303B
U.S. N/A 4AT
U.S. N/A 5MT 4.273 A05B
U.S. N/A 6MT
U.S. T.T 4AT
U.S. T.T. 6MT
U.K. T.T. 6MT 3.133 B03B
U.K. T.T. 4AT
Anyone with any other codes/ratios for the record?
