Supra N_A Posted March 25, 2012 Share Posted March 25, 2012 any ideas people ? it only seems to boost to 0.5bar will not go over just installed the following : double decats RR FMIC HKS FCD (setting 9) think could be a boost leak?? it did boost amazing till one pipe popped off from the fmic but checked and all are back on fine.. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 25, 2012 Share Posted March 25, 2012 You need different spark plugs too really. 0.5 is first turbo boost pressure. Does the 2nd turbo cut in? Check the vsv's. Sometimes they stick and the 2nd turbo doesn't come on. Quote Link to comment Share on other sites More sharing options...
Slicknick Posted March 25, 2012 Share Posted March 25, 2012 Don't forget about upgrading the fuel pump too! Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 25, 2012 Author Share Posted March 25, 2012 forgot to mention people this already has a walbra fuel pump and uprated spark plugs (i THINK) the previous owner installed these when sold and jurgen did not remove them so.. how would i kno it has them with out taken the pump out etc? Quote Link to comment Share on other sites More sharing options...
tony tt Posted March 25, 2012 Share Posted March 25, 2012 Does sound like boost leak from somewhere id check everything over all fmic fittings and vsv's Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 25, 2012 Author Share Posted March 25, 2012 whats the vsv all about mate?? can they pop off or summit? Quote Link to comment Share on other sites More sharing options...
dude Posted March 25, 2012 Share Posted March 25, 2012 forgot to mention people this already has a walbra fuel pump and uprated spark plugs (i THINK) the previous owner installed these when sold and jurgen did not remove them so.. how would i kno it has them with out taken the pump out etc? You will need to check the pump toknow for sure, is it smoking at all ??? Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 25, 2012 Author Share Posted March 25, 2012 You will need to check the pump toknow for sure, is it smoking at all ??? no no smoking at all like i said I had it to 1/1.2 bar before the silicone joiner popped off and now put back on correctly it only boosts to 0.5.. will have to open the fuel pump out or is there any other way of knowing ? Quote Link to comment Share on other sites More sharing options...
dude Posted March 25, 2012 Share Posted March 25, 2012 Pump is not your problem, check all the vacuum lines Quote Link to comment Share on other sites More sharing options...
