Rummy Posted March 25, 2012 Share Posted March 25, 2012 Afternoon! Backstory - (Manual N/A, J-spec) Slowly been losing oil after long drives so I top up pretty much before most journeys. After the car has warmed up in situ there is often a puddle of oil on the ground. I topped up today as normal and overfilled so the level showed above full, which I was slightly worried about. Half an hour into journey all was fine until I accelerated onto a duel carriage way and that's when I noticed the smell of fresh oil. Shortly after, the water temp rose into the red followed by the engine temp hitting the red. Exiting the carriageway white smoke came from the rear and engine but only at low speed. I pulled over to investigate and found evidence of oil sprayed around mid/top of engine and fresh oil over the back of the car. The dip stick (wiped) still showed above full too. Upon restarting the engine it struggled to catch and made some nasty clanking sounds, but once started sounded ok. Water temp went down but engine stayed high and the clutch started to slip on the limp back home. So is it likely to be a blown seal(s)? top or bottom end? or worse, mechanical? I'm going to check the level again when it's cooled a bit more and see what other interesting sounds come out. Help/Advice appreciated before I take it to a garage to get ripped off. Many thanks Link to comment Share on other sites More sharing options...
Scooter Posted March 25, 2012 Share Posted March 25, 2012 I would try and organise or at least get some quotes for a whole engine swap with Keron or another trader. Link to comment Share on other sites More sharing options...
JamieP Posted March 25, 2012 Share Posted March 25, 2012 Losing oil and the clutch slipping makes me think the rear main seal might be gone. There may be more than just the one issue, oil leak wont effect water temps, clanking sound on fire up dont sound good, you need to get it to somebody that knows what they are looking at. Link to comment Share on other sites More sharing options...
Rummy Posted March 25, 2012 Author Share Posted March 25, 2012 Thanks guys. I investigated further and it turns out one of the coolant pipes to the top rear of engine has ruptured. So that explains that. I topped up the rad and the engine temp went back down and no clanking! Maybe the clutch slip was due to the engine overheating so much the oil got too thin? I dunno..just hoping! Link to comment Share on other sites More sharing options...
Rummy Posted March 30, 2012 Author Share Posted March 30, 2012 OK, here's the new sketch. Located and replaced the split water heater hose. Refilled cooling sytem. Test drive. Outcome, several times the coolant kept getting pushed to almost overflow in the expansion tank and blew the lid off. Rad cap off - no coolant seen in rad. I've tried several times to bleed the air out with heater on full with the same result. So I took a quick look for leaks - none found. Took the oil fill cap off and the white cream sludge of death was evident on the bottom of the cap Soooooooo, BHG? If so (FFS) what sort of cost am I expecting to fix it? Link to comment Share on other sites More sharing options...
mellonman Posted March 30, 2012 Share Posted March 30, 2012 its cheaper to get another n/a engine mate there cheap about £300 Link to comment Share on other sites More sharing options...
fastcar Posted March 30, 2012 Share Posted March 30, 2012 Losing oil and the clutch slipping makes me think the rear main seal might be gone. There may be more than just the one issue, oil leak wont effect water temps, clanking sound on fire up dont sound good, you need to get it to somebody that knows what they are looking at. Link to comment Share on other sites More sharing options...
Rummy Posted March 30, 2012 Author Share Posted March 30, 2012 The leaking oil was coming from the oil filter seal. There's no more clanking either, just the cooling issue. So with that in mind is it still not worth getting the HG replaced as everything else is ok? Link to comment Share on other sites More sharing options...
Swampy442 Posted March 30, 2012 Share Posted March 30, 2012 Get a Sniff test done by a garage, they can identify pretty much straight away if it's an hg Link to comment Share on other sites More sharing options...
