spark plug coated in oil...please help :(
GTR Fever
hey guys,
drove my car and noticed a slight misfire. knowing that the car is garaged alot, i figured the plugs needed cleaning. took out the one from no.6 cylinder and its completey coated in oil...top to bottom..even the coilpack has some oil on it..didnt take out any other spark plugs tho, just that one..
what can cause this? are my piston rings gone?
thank you in advance
PROBLEM FIXED....THANKS GUYS!!
Edited by GTR Fever (see edit history)
Im just about to start swapping my seals this morning, ive not checked the spark plugs yet, but ive got oil all down the side of my cam covers so theres a good chance ill find it in the spark plug wells. I ordered both seals from Paul Whiffin on here, think they are about £10 each. But ive also replaced all 16 washers that hold down the cam covers aswell, as these have rubber bases on them that make a tight seal, and they can also perish over time.
Get some brake cleaner from Halfords to clean up any oil spills :)
oh ok...thanks guys
but i have oil on the tip of the spark plug as well..the ENTIRE plug was covered in oil. also, car used to puff some smoke on cold start but it doesnt smoke at all anymore..
any1 i can order the cam cover seals from though? Trinidad sucks with getting new parts..
  • 2 weeks later...
