GTR Fever Posted March 25, 2012 Share Posted March 25, 2012 (edited) hey guys, drove my car and noticed a slight misfire. knowing that the car is garaged alot, i figured the plugs needed cleaning. took out the one from no.6 cylinder and its completey coated in oil...top to bottom..even the coilpack has some oil on it..didnt take out any other spark plugs tho, just that one.. what can cause this? are my piston rings gone? thank you in advance PROBLEM FIXED....THANKS GUYS!! Edited April 6, 2012 by GTR Fever (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 25, 2012 Share Posted March 25, 2012 Piston rings won't affect the coil pack. More than likely it's your cam cover gaskets leaking oil into the plug wells. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 25, 2012 Share Posted March 25, 2012 Have you or someone else topped it up recently? Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 25, 2012 Share Posted March 25, 2012 If its on the outside of the plug and the coilpack it will more than likely be the cam cover seals Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 25, 2012 Share Posted March 25, 2012 exactly the same here, changed the plugs yesterday and 2 of the 6 plugs were covered in oil over the coilpacks too but im almost sure on mine its the cam cover as said above? ive nipped them all up now i forgot to do a couple last time Quote Link to comment Share on other sites More sharing options...
Havard Posted March 25, 2012 Share Posted March 25, 2012 Piston rings won't affect the coil pack. More than likely it's your cam cover gaskets leaking oil into the plug wells. This. Had it on my NA. H. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 25, 2012 Share Posted March 25, 2012 (edited) Old cam cover seals go hard over time/milage and should be replaced along with the washers on the bolts as they have seals on each one Edited March 25, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 25, 2012 Share Posted March 25, 2012 ill have to replace mine then dunk i guess they dont cost much anyway, and they probably never been changed Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted March 25, 2012 Share Posted March 25, 2012 Im just about to start swapping my seals this morning, ive not checked the spark plugs yet, but ive got oil all down the side of my cam covers so theres a good chance ill find it in the spark plug wells. I ordered both seals from Paul Whiffin on here, think they are about £10 each. But ive also replaced all 16 washers that hold down the cam covers aswell, as these have rubber bases on them that make a tight seal, and they can also perish over time. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 25, 2012 Share Posted March 25, 2012 Im just about to start swapping my seals this morning, ive not checked the spark plugs yet, but ive got oil all down the side of my cam covers so theres a good chance ill find it in the spark plug wells. I ordered both seals from Paul Whiffin on here, think they are about £10 each. But ive also replaced all 16 washers that hold down the cam covers aswell, as these have rubber bases on them that make a tight seal, and they can also perish over time. Get some brake cleaner from Halfords to clean up any oil spills Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted March 25, 2012 Share Posted March 25, 2012 Lol, i was just about to post asking what i should use to remove all the old oil from the cam covers/plugs etc. Thanks alot. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 25, 2012 Share Posted March 25, 2012 Lol, i was just about to post asking what i should use to remove all the old oil from the cam covers/plugs etc. Thanks alot. No problem They sell it in a nice handy spray tin as well Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted March 25, 2012 Author Share Posted March 25, 2012 oh ok...thanks guys but i have oil on the tip of the spark plug as well..the ENTIRE plug was covered in oil. also, car used to puff some smoke on cold start but it doesnt smoke at all anymore.. any1 i can order the cam cover seals from though? Trinidad sucks with getting new parts.. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 25, 2012 Share Posted March 25, 2012 mine was on the tip too mate and the thread must be where it runs down, mine was all over the rubber part on the coil packs too around the ends on the far sparkplug and the 2nd one in form the front Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted March 25, 2012 Author Share Posted March 25, 2012 thanks alot..I feel wayyy better now. Was thinking I would have to tear apart the motor and build it over. where can I get those cam cover gaskets? Can't get them in Trinidad and don't know where to order them from. thanks again. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 25, 2012 Share Posted March 25, 2012 If theres no Toyota dealer there try Whifbits here in the UK, sure he'd post. Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted April 6, 2012 Author Share Posted April 6, 2012 hey guys...just wanna say thanks for all the advice..finally changed the cam cover gaskets, VSV sensor (one was broken) and cleaned up coilpacks and plugs...car works totally different!! feels amazing, plenty of power..thanks again guys! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 6, 2012 Share Posted April 6, 2012 That's what we're here for, good work Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted April 7, 2012 Author Share Posted April 7, 2012 yeah, was a simple DIY..just took some time.. next step, fix my oil leak Quote Link to comment Share on other sites More sharing options...
